How to fix UPGRADING to 9.4.1 from 9.1.1 (and possibly older versions)
 28 Subscribed to this forum
Wanted to upgrade to 9.4.1. from 9.1.1. The process was OK, all items were GREEN, except for the one with Telerik 09.02.01_install.zip (FAILED - RED).
For some reason, I saw the Telereik 9.2.1 (? wtf ?)  version reference as faulting. So I went back, and did a DNN upgrade to 9.2.1 from 9.1.1. This went through OK. Then I did an upgrade from 9.2.1 directly to 9.4.1. -- everything went through OK, and the website worked OK. :)
SUGGESTION: the 9.4.1. upgrade has a reference to Telerik 9.2.1, which should probably be removed or even just renamed to 9.4.1.
(I do have another UNRESOLVED issue, after upgrading from 9.1.1. It is because of a custom SKIN that I use. This is HammerFlex from Chris Hammond. The only issue I see, is that the HOST/ADMIN functionality is broken - I see a gray stripe on the left, but no HOST/ADMIN icons or links. I resolved this, by putting Xcillin SKIN files in the HammerFlex folder, and then overriding it with all the files from the original HammerFlex SKIN folder. Then, the HOST/ADMIN overlay worked, so I could choose another SKIN, which would eliminate the problem. SUGGESTION: there should be the possibility of reaching the HOST/ADMIN section through a normal query string or special URL, which would eliminate this and all other possible future SKIN problems, quirks & errors).
So, as far as I am concerned, everything is resolved here.
Keep up the good work guys, DNN rulez! 8-)
FYI, Chris has an update to Hammerflex that (I hope) is also compatible with 9.4.1.
There is also a Hammerflex2 that uses Bootstrap 4.
Hammerflex - the 2019 updated version works properly with 9.4.1. Very nice!
I noticed, that the Messaging section now works also. Before it was "Loading messages...".  This is good, cause I did not have time today, to do extensive debugging. Win-win. :)
THANK YOU!
