Hello Forum
I've setup a brand new Installation of the actually DNN version. All works fin until Step 2 (continue Installation....after Step 1 given Account names...SQL etc.). The Process hang with the description "...failure. The Applicatinpool has to start into the integrated modus" . So, now i changed in IIS the Pool to "integrated" . Restart the Pool...Start from new the IIS and run the Installwizard....but the website still jump to the point descript above. So whats the solution to finaly setup the website ? Any Ideas ? Thanks for your support rte
Hi Michael Here the Log-Entry: 2021-07-21 09:23:59.413+02:00 [MYServer][D:3][T:9][ERROR] DotNetNuke.ComponentModel.ProviderInstaller - System.Configuration.ConfigurationErrorsException: Could not load provider DNNConnect.CKEditorProvider.CKHtmlEditorProvider, DNNConnect.CKEditorProvider 2021-07-21 09:24:00.606+02:00 [MYServer][D:3][T:9][ERROR] DotNetNuke.Data.PetaPoco.PetaPocoHelper - [1] Error executing SQL: ;Exec dbo.GetDatabaseVersion Could not find stored procedure 'dbo.GetDatabaseVersion'.
Not really helpful for me, but maybe you have a idea for it ? Thanks Remo
Vers. 9.1 ....it is a internal Webserver on Win 2019SRV with SQL2017.
And yes i try to install with nvQuickSite...but it gives me always Permission-Errors when i try to install/generate a Website. Thats why i choos to install manual....
There might be two issues:
1) did you unblock the ZIP file before extracting? 2) the application pool needs modify permissions in the file system (folder, where you install DNN and sub-folders) and membership in the db_owner role for the database. (Please read Secure your DNN Database by some simple steps (dnncommunity.org) to learn how to reduce the database permissions later.)
Did you check that?
Happy DNNing! Michael
i already did this steps, but unfortunatly when i restart IIS and start the installwizard.aspx...it will go automatically to step 2 where it hangs. it doesn't start the installwizard from new. where/how can i reset the installwizard ?
