Module installation problem on PAAS - AZURE istance
 28 Subscribed to this forum
Dear all,
we upgraded our UAT old version 9.1.1 with the 9.10.2 (following the official documentation). During the upgrading we had a problem with the library microsoft.windowsazure.storage.dll (not found) and we manually added via FTP; by doing so we were able to complete the upgrade to the v.9.10.2.
At the moment we've another problem with the installation of a third part module "EasyDnnNews": the installation fail during the clean up step of temp dir; this is a extrapolation of the log:
"Dnn.PersonaBar.Extensions.Services.ExtensionsController - SchwabenCode.QuickIO.PathNotFoundException: The system cannot find the path specified.
at SchwabenCode.QuickIO.Internal.InternalQuickIOCommon.NativeExceptionMapping(String path, Int32 errorCode)
at SchwabenCode.QuickIO.Internal.InternalQuickIO.EnumerationHandleInvalidFileHandle(String path, QuickIOEnumerateOptions enumerateOptions, Int32 win32Error)
at SchwabenCode.QuickIO.Internal.InternalQuickIO.FindPaths(String uncDirectoryPath, String pattern, SearchOption searchOption, Nullable`1 filterType, QuickIOEnumerateOptions enumerateOptions, QuickIOPathType pathFormatReturn)
at SchwabenCode.QuickIO.Internal.InternalQuickIO.EnumerateDirectoryPaths(String path, String pattern, SearchOption searchOption, QuickIOEnumerateOptions enumerateOptions, QuickIOPathType pathFormatReturn)
at DotNetNuke.Common.Utilities.FileSystemUtils.DeleteFolderRecursive(String strRoot)
at DotNetNuke.Services.Installer.Installer.Install()
at Dnn.PersonaBar.Extensions.Components.InstallController.InstallPackage(PortalSettings portalSettings, UserInfo user, String legacySkin, String filePath, Stream stream, Boolean isPortalPackage)
at Dnn.PersonaBar.Extensions.Services.ExtensionsController.InstallPackageFile(String filePath)
at Dnn.PersonaBar.Extensions.Services.ExtensionsController.InstallAvailablePackage(DownloadPackageDto package)"
someone can help?
regards
First, welcome to the community.
Two questions:
Did you download the upgrade package, not the source?
Did you unblock the ZIP file before unpacking?
Hi Michael,
thankyou very much!
1) Yes we download and install the upgrade package
2) I'm not sure, we'll try again restoring an old backup and unblocking the zip file.
i will give you a feedback :)
