Upgrade from 742 to 804. Help, what happens at my site
 28 Subscribed to this forum
Hello,
I upgraded my site and some modules but I don't know what is happened and I no longer have the control panel. Any suggestions is apreciated.
site:  informatori.info.tempdomain.com/
Thanks a lot
I think that you are going to need to proved a few more details.
Posted By Sh@wn01 on 10 Jan 2021 11:02 AM
Hello,
site:  informatori           .   info
Thanks a lot
What exactly did you do? Also: I sure hope you made a backup..
Hello, thanks for your reply.
You can see the website here: informatori.info.tempdomain.com
Before the upgrade I run TurboUnSchema932.sql script by Sebastian Leupold and no error in log file after upgrade.
I read also this thread :
https://www.dnnsoftware.c...e/posts/threadpage/1
The site structure is broken and now I get this error:
2021-01-18 17:30:32,515 [Generic284][Thread:25][FATAL] DotNetNuke.Framework.PageBase - An error has occurred while loading page.
System.Data.SqlClient.SqlException (0x80131904): Invalid column name 'DefinitionName'.
at System.Data.SqlClient.SqlDataReader.TryConsumeMetaData()
at System.Data.SqlClient.SqlDataReader.get_MetaData()
at System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString, Boolean isInternal, Boolean forDescribeParameterEncryption, Boolean shouldCacheForAlwaysEncrypted)
at System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async, Int32 timeout, Task& task, Boolean asyncWrite, Boolean inRetry, SqlDataReader ds, Boolean describeParameterEncryptionRequest)
at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, TaskCompletionSource`1 completion, Int32 timeout, Task& task, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry)
at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method)
at System.Data.SqlClient.SqlCommand.ExecuteReader(CommandBehavior behavior, String method)
at DotNetNuke.Data.PetaPoco.PetaPocoExt.ExecuteReader(Database database, String sql, Object[] args)
at DotNetNuke.Data.SqlDataProvider.ExecuteReader(String procedureName, Object[] commandParameters)
at DotNetNuke.Entities.Modules.ModuleController.GetModuleByDefinition(Int32 portalId, String definitionName)
at DotNetNuke.UI.ControlPanels.ControlBar.GetTabURL(List`1 additionalParams, String toolName, Boolean isHostTool, String moduleFriendlyName, String controlKey, Boolean showAsPopUp)
at DotNetNuke.UI.ControlPanels.ControlBar.BuildToolUrl(String toolName, Boolean isHostTool, String moduleFriendlyName, String controlKey, String navigateUrl, Boolean showAsPopUp)
at ASP.admin_controlpanel_controlbar_ascx.__RenderControlPanel(HtmlTextWriter __w, Control parameterContainer)
at System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children)
at System.Web.UI.WebControls.WebControl.RenderContents(HtmlTextWriter writer)
at System.Web.UI.WebControls.WebControl.Render(HtmlTextWriter writer)
at System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter)
at ASP.admin_controlpanel_controlbar_ascx.__Render__control1(HtmlTextWriter __w, Control parameterContainer)
at System.Web.UI.HtmlControls.HtmlForm.RenderChildren(HtmlTextWriter writer)
at System.Web.UI.HtmlControls.HtmlContainerControl.Render(HtmlTextWriter writer)
at System.Web.UI.HtmlControls.HtmlForm.RenderControl(HtmlTextWriter writer)
at DotNetNuke.Framework.PageBase.Render(HtmlTextWriter writer)
at DotNetNuke.Framework.DefaultPage.Render(HtmlTextWriter writer)
ClientConnectionId:75db1c21-5fff-47fe-a907-4a49d7857fff
I don't know what can I do....
How Can replace: System.Data.SqlClient.SqlException (0x80131904): Invalid column name 'DefinitionName' ?
I sent you a private message.
Hello
I run TurboDNN932.sql (TurboDNN099z8.zip) in www.informatori.info.tempdomain.com and now the site upgrade to dnn804 is again online but it is unusable.
I tried to avoid problems before the upgrade and I installed default gravity skin. It is an issue loading static content? css or images?
but now I see another error when I try to open host/dashboard page.. is it possible that for some reasons the upgrade haven't change the new namespace required for dnn8?
you can see here the dnn8 namespace change here:
https://www.c-sharpcorner...-dnn-from-704-to-803
and this is the error that I get:
____________________________________________________________
2021-01-19 12:30:07,812 [Generic284][Thread:20][FATAL] DotNetNuke.Framework.PageBase - An error has occurred while loading page.
System.TypeLoadException: Could not load type 'DotNetNuke.Modules.Dashboard.Components.IDashboardData' from assembly 'DotNetNuke, Version=8.0.4.226, Culture=neutral, PublicKeyToken=null'.
at DotNetNuke.Modules.SocialDashboard.Controls.SocialDashboard.Page_Load(Object sender, EventArgs e)
at System.Web.UI.Control.OnLoad(EventArgs e)
at DotNetNuke.Entities.Modules.PortalModuleBase.OnLoad(EventArgs e)
2021-01-19 12:30:07,814 [Generic284][Thread:20][ERROR] DotNetNuke.Services.Exceptions.Exceptions - ~/Default.aspx?tabid=776&error=Could+not+load+type+%27DotNetNuke.Modules.Dashboard.Components.IDashboardData%27+from+assembly+%27DotNetNuke%2c+Version%3d8.0.4.226%2c+Culture%3dneutral%2c+PublicKeyToken%3dnull%27.&content=0
thanks
it looks like therer are issues loading static files (.css, .js and images)
please check website permissions.
ps: I wouldn't care about the dashboard issue - this module has been remove in DNN 9.2
