Adding Service Reference to a custom module
Hello,
I am having a issue when I create a service refernce within a custom module.  The service refernce gets created and it generated code as usual.  But the problem I am having is when I copy the system.service model section from web.config that was created in my module to the actual web.config - I get the green squiggly of death. The error says: "Warning        The 'contract' attribute is invalid - The value 'FedExServiceRef.RatePortType' is invalid according to its datatype 'clientContractType' - The Enumeration constraint failed."  I can recreate the error by simply creating another web forms project and renaming the contract portion.  Or by just renaming the contract portion within my custom module.  I have tryed to rename it to : fully qualified name like :DotNetNuke.Modules.BC_CustomerCart.[rest is whatever was put in by creation.].  I cannot make the green squiggly go away or even connect to the service.
Any help is appreciated.
Can you provide an example of the code you are trying to use?
Thanks for the reply - but I guess its the case of the green squiggly everywhere else in a dnn application.
It was my problem as far as connecting to service.
