Admin instead of Page Theme loads on View Control Type.
I am working on enhancing an old asp.net C# compile web module started from the Cristoc templates. The goal of this page is to embed in an iframe for use on other sites and I could create a whole new portal and put this page into it and select the admin page theme to be a minimalist theme with a single container but I'd rather figure out why DNN (8.0.3) is loading the admin skin instead of the default skin.
It has numerous controls defined such as:
Default View . source desktopmodules/module/view.ascx  Type: View
Category source desktopmodules/module/category.ascx  Type Edit
Send source source desktopmodules/module/send.ascx Type View
Send.ascx is navigated to by the onclick event of a link button:
this.Response.Redirect(Globals.NavigateURL(this.PortalSettings.ActiveTab.TabID, "Send", "mid=" + this.ModId.ToString() + & "detailId=" + commandArgment)
When Send.ascx loads, the expected and desired behavior is that the site's default page theme is loaded by DNN. However, I can't figure out why the configured Admin theme is loaded for this page.
I went through the module definitions and even changed the send control to be the view type from its previous value and this had no effect on the fact that DNN loads the Admin vs the desired page theme file.Also note on the site the module is actually running there is a specific page theme of the minimalist version and when user advances to the last step they get the whole tamale of DNN instead of the minimalist them.
Thanks in advance!!
by default, only module controls of type "view" are displayed using the page skin, all modules controls with keys edit, settings and other are displayed using site admin skin. In your own module, you may use a dispatcher control (type view), which reads the control to used by itself from the query string.
HTH
I have gone into the module definitions and ensured that the "Send" control specified is "View" type. I am perplexed still why when the page is accessed accordingly in the globals.navigateurl specified previously it should by all rights be loading the default theme and not the edit theme.
Additional thoughts other than refactoring the detailview control I have to programmatically load this send control would be much appreciated. Perhaps I am missing something from configuration somewhere?
Send Control Manifest File DefinitionSend Control Extensions
