Building DNN Platform / Alpha Version Page Title
Hi!
I hope this is the right section of the forum.
I tried to make a build of version 9.4.1 and when I put the files online I got the "Alpha Version" appended to the title. I simply ran .\Build.Ps1. For now I set "DisplayBetaNotice" to "N" in the HostSettings table to get rid of it.
Is there some way to make a build that doesn't require changing the HostSettings table? Am I missing some options or changing some config file before making the build? Was this something only occurring with 9.4.1 and got fixed later?
I would be glad for any sort of info.
Andy9999
You'll need to switch the <code>AssemblyStatus</code> attribute in <code>DNN Platform/Library/Properties/AssemblyInfo.cs</code>.
Thank you so much Brian! :) Setting it to ReleaseMode.Stable instead of ReleaseMode.Alpha fixed it.
Adding this to the page title is of little use in my opinion. With the current web browsers, you won't notice it most likely. Especially if you already have SEO optimized titles using 50 to 60 characters. I noticed it in Google Analytics. But it was too late and already indexed. In search results you will notice it as well. Am now waiting for Google to index the proper page titles again.
Is it normal that the official release source code zip file has this set to alpha? And the Github release as well? It totally backfired in my case.
But anyways, now I know what to check before building DNN again and putting it on the live server. Thanks again!
