DAL2 - How to count records?
Hi all,
I need to count records in a module. I wrote a stored procedure:
CREATE PROCEDURE dbo.dnn_CountOutdatedRecords
   @ModuleID int,
   @StartDate datetime
AS
BEGIN
   SET NOCOUNT ON
   SELECT
      COUNT(*)
   FROM
      dbo.dnn_Records
   WHERE
      ModuleID = @ModuleID
      AND StartDate <= @StartDate
END
In the controller I wrote the following code:
public int OutdatedRecordsCount(int moduleID, DateTime startDate)
   int outdatedRecordsCount;
   using (IDataContext ctx = DataContext.Instance())
      outdatedRecordsCount = ctx.ExecuteScalar(System.Data.CommandType.StoredProcedure, "{databaseOwner}{objectQualifier}CountOutdatedRecords", new object[] { moduleID, startDate });
   return outdatedRecordsCount;
This always returns 0 (zero), even if I get a number selected when I execute the stored procedure. I tried with an OUTPUT parameter:
   @ModuleID int,
   @StartDate datetime,
   @OutdatedRecordsCount OUTPUT
AS
BEGIN
   SET NOCOUNT ON
   SELECT
      @OutdatedRecordsCount = COUNT(*)
   FROM
      dbo.dnn_Records
   WHERE
   RETURN @OutdatedRecordsCount
END
And in the controller:
   int outdatedRecordsCount = 0;
      ctx.ExecuteScalar(System.Data.CommandType.StoredProcedure, "{databaseOwner}{objectQualifier}CountOutdatedRecords", new object[] { moduleID, startDate, outdatedRecordsCount });
This fired an exception, "Null object cannot be converted to a value type'. I changed the controller to a text command:
      outdatedRecordsCount = ctx.ExecuteScalar(System.Data.CommandType.Text, "SELECT COUNT(*) FROM {databaseOwner}{objectQualifier}Records WHERE ModuleID = @0 AND StartDate <= @1", new object[] { moduleID, startDate });
This also returns 0 (zero).
Any idea how to get this done right?
Solved it.
Instead of the stored procedure I created a function:
CREATE FUNCTION dbo.dnn_f_CountOutdatedRecords
   @ModuleID int,
   @StartDate datetime
RETURNS int
AS
BEGIN
   DECLARE @OutdatedRecordsCount int
   SELECT
   FROM
      dbo.dnn_Records
   WHERE
END
GO
In the controller I use the follwing code:
public static int OutdatedRecordsCount(int moduleID, DateTime startDate)
      outdatedRecordsCount = ctx.ExecuteScalar(System.Data.CommandType.Text, "SELECT {databaseOwner}{objectQualifier}f_CountOutdatedRecords(@0, @1)", new object[] { moduleID, startDate });
Eh, voila!
Anyway, if someone could post an example (or write a blog) of how to work with stored procedures that return an output parameter in DAL2 - this would be interesting.
If I wanted to get a single value from a stored procedure, this is how I'd do it:
<code>
CREATE OR ALTER PROCEDURE CountOutdatedRecords (
    @ModuleId int,
    @StartDate datetime
AS
BEGIN
    SELECT @moduleId + DATEDIFF(ns, GETUTCDATE(), @StartDate)
END
GO
</code>
From the SQL, just <code>SELECT</code> the value you want.
<code>
protected int GetValue()
        return ctx.ExecuteScalar<int><int>(
            new object&#91;&#93; { ModuleConfiguration.ModuleID, DateTime.Now });
</int></code>
Using <code>ExecuteScalar</code> will get that single value from the <code>SELECT</code> result set.
If you need to use an <code>OUTPUT</code> parameter, this will work:
<code>
  @ModuleId int,
  @OutdatedRecordsCount int OUTPUT
AS
BEGIN
    SELECT @moduleId + DATEDIFF(ns, GETUTCDATE(), @StartDate);
    SET @OutdatedRecordsCount = 123;
END
GO</code>
<code>
protected int GetOutputValue()
        var count = new SqlParameter("@OutdatedRecordsCount", SqlDbType.Int)
                Direction = ParameterDirection.Output
        ctx.Execute(
            new SqlParameter("@ModuleId", ModuleConfiguration.ModuleID),
            new SqlParameter("@StartDate", DateTime.Now),
            count);
        return (int)theResult.Value;
}</code>
Hope it helps!
Thanks Brian, I'll try that.
