Delete users programmatically
Hello,
deleting all users by the method
[CODE]
UserController.DeleteUsers(int portalId, bool notify, bool deleteAdmin)
[CODE],
I ran into this error:
[CODE]
   at DotNetNuke.Entities.Users.UserController.UpdateUser(Int32 portalId, UserInfo user, Boolean loggedAction, Boolean sendNotification, Boolean clearCache) in C:\DNN\09.11.2\DNN Platform\Library\Entities\Users\UserController.cs:line 1917
   at DotNetNuke.Entities.Users.UserController.UpdateUser(Int32 portalId, UserInfo user, Boolean loggedAction, Boolean sendNotification) in C:\DNN\09.11.2\DNN Platform\Library\Entities\Users\UserController.cs:line 1275
   at DotNetNuke.Entities.Users.UserController.UpdateUser(Int32 portalId, UserInfo user, Boolean loggedAction) in C:\DNN\09.11.2\DNN Platform\Library\Entities\Users\UserController.cs:line 1265
   at DotNetNuke.Entities.Users.UserController.UpdateUser(Int32 portalId, UserInfo user) in C:\DNN\09.11.2\DNN Platform\Library\Entities\Users\UserController.cs:line 1256
   at DotNetNuke.Entities.Users.UserController.DeleteUser(UserInfo& user, Boolean notify, Boolean deleteAdmin) in C:\DNN\09.11.2\DNN Platform\Library\Entities\Users\UserController.cs:line 500
   at DotNetNuke.Entities.Users.UserController.DeleteUsers(Int32 portalId, Boolean notify, Boolean deleteAdmin) in C:\DNN\09.11.2\DNN Platform\Library\Entities\Users\UserController.cs:line 514
[CODE]
The method
[CODE]
UserInfo GetUserById(int portalId, int userId)
[CODE]
return NULL executing this line of code:
[CODE]
user = MembershipProvider.Instance().GetUser(GetEffectivePortalId(portalId), userId);
[CODE]
I'm using AspNetMembershipProvider
Scenario: I'm porting some modules developed for DNN 7.4 to DNN 9.11.2, and I noticed the call to [CODE]
UpdateUser(portalId, GetUserById(portalId, user.UserID))
[CODE] was added.
Any idea on how to get around the problem?
S.
I don't have a quick resolution, but curious if you have portal groups setup?
We have a module that deletes users, you can find the code here and it is working in DNN 9.11.2:
https://github.com/40fing...rsController.cs#L228
Posted By Daniel Valadas on 2/1/2024 2:13 PM
Hi Daniel,
I've installed and configured only one portal, updating it from 7.4 using the recommended steps up to 9.11.2
Posted By Timo Breumelhof (40F) on 2/1/2024 5:20 PM
Hi Timo,
I've seen you are using UserController's API...have you never tested the DeleteUsers? :-\
If you join our discord and attend one of our co-coding sessions, happy to try to pinpoint it with you.
Alternatively, if you can do a minimal module that makes this bug happen, you could create an issue with it at https://github.com/dnnsof.../Dnn.Platform/issues which would make it easy to test/fix.
Posted By Daniel Valadas on 2/2/2024 3:13 AM
Opened an issue on GitHub.
Could you be more specific on "If you join our discord and attend one of our co-coding sessions, happy to try to pinpoint it with you."
S.
Discord is a messaging app and we do co-coding sessions (live audio/video streaming) almost every week to co-code and help people on anything open-source related to DNN. If you go to the home page of this very site, you will see near the bottom a panel with a button to join our discord. Once there you will see "Events" and you can see when the next ones occur and join them. It is a great way to look into more complex issues live.
Problem found, there is a trigger on the db that remove the record immediately :-|
Is there a setting at portale level to do that?
Thanks again
Posted By Seek78 on 2/5/2024 1:39 PM
Thanks again
I am unaware of any triggers in the DNN database by default.  So, this must have been added by someone.
