DNN 9.1.1 and Site Setting
Hi, I've a DNN site. Current is v9.1.1, started is 8.0.3
I developed custom modules and I add some custom setting inside Module Settings Tab (https://invisiblefarm-my....l_zlQtx0zg?e=6WDx3t)
I used this code
                ModuleController moduleController = new ModuleController();
                PortalSettings portalSettings = (PortalSettings)HttpContext.Current.Items["PortalSettings"];
                ModuleInfo moduleInfo = moduleController.GetModuleByDefinition(portalSettings.PortalId, "Site Settings");
                int GlobalId = moduleInfo.ModuleID;
                Hashtable globalSettings = moduleController.GetModuleSettings(GlobalId);
                if (globalSettings.Contains(key))
                    return globalSettings[key].ToString();
                else
                    return _default;
to open Settings Module
I notice, with v9.1.1, var moduleInfo is always NULL because "Site Settings" isn't in DB (table ModuleDefinitions): what'is the workaround?
Take a look at Chris Hammond's templates (christoc.com) for building modules and you'll see examples of how to do this.
Thanks Joe, I'll look the tutorial ASAP!
 Which one in particular?
Hi Joe,
I watched tutorials like you suggested but I didn't find the solution at my problem.
With the code I had posted, I obtain this globalSettings hashtable (this is my module settings)
Count = 4
    ["max_anno"]: "2019"
    ["west_nile_search_url"]: "/cerca"
    ["search_url"]: "/../../cerca"
    ["min_anno"]: "2017"
With DNN 9.1.0, moduleController.GetModuleByDefinition(portalSettings.PortalId, "Site Settings") always return NULL value: why? Is there an alternative? Consider that this method is in an abstract class that is used a in my code by module Settings class
Not a tutorial, but Chris' templates.
