Documentation about creating Persona Bar extensions without react
I couldn't find any documentation.
I'm trying to create a not-react persona bar extension using Vue.
A trivial module that does nothing and reference nothing works fine.
The problem is, when I try to do something real.
(1)
How do I create and call my web services (services framework)?
The best I could find is: https://stackoverflow.com...a-bar-module-routing
It doesn't work for me.
How should I create my services class? How should I make it available by code and/or registering it in the manifest (.DNN) file? How do I use it? [web-root]/API/PersonaBar/..... something? Or something else? What exactly?
(2)
How do I use localization?
All the code in DNN refers to a 'util.js' which has a method like getResx().
How do I access it and use it from my not-react module?
I've improvised... I guess there are many things terribly wrong.
Final result: https://github.com/horacioj/dnnsearchandreplace
Any feedback is welcome.
