Integrating Dropzone - Reference Issue
Hey!
I'm trying to set up Dropzone file upload on my DNN 9.4.4 site - Hotcakes 3.2.3 is installed as a module as well.
In order to handle the files on the server side, I used the latest DNN template by Chris (https://github.com/ChrisHammond/DNNTemplates) to create a C# DAL2 MVC Module and followed his instruction videos https://www.youtube.com/w...Z8fswIbNZFd&index=11
Since the target framework in DNN 9.4.4 is .NET 4.7.2 I changed it on the template as well.
After that, I added my Controller, compiled it and installed it as an extension. However, when calling my action url: '/DesktopModules/MVC/DropzoneHandler/Dropzone/Upload' I just receive an assembly reference error:
Server Error in '/desktopmodules/mvc/DropzoneHandler' Application.
Could not load file or assembly 'Hotcakes.Commerce.Dnn' or one of its dependencies. The system cannot find the file specified.
There's no reference to Hotcakes assemblies anywhere in that project, nevertheless some subassembly is looking for various Hotcakes.dlls within /DesktopModules/MVC/DropzoneHandler/bin - they are located in the root/bin folder and if I copy them over, it's working.
I tried to figure out what's calling those DLLs using the Fusion log, that didn't work. Via Process Monitor I found out where it's looking for the DLLs.
Does anyone have an idea how to solve this issue?
Controller:
using System.Web.Mvc;
using System.IO;
using DotNetNuke.Web.Mvc.Framework.Controllers;
using DotNetNuke.Web.Mvc.Framework.ActionFilters;
namespace Wiremayr.Modules.DropzoneHandler.Controllers
    [DnnHandleError]
    public class DropzoneController : DnnController
        public JsonResult Upload(int itemId)
            string imageUrl = string.Empty;
            string imgPath = Server.MapPath("~/Uploads/");
            if (!Directory.Exists(imgPath))
                Directory.CreateDirectory(imgPath);
            foreach (string s in Request.Files)
                var file = Request.Files[s];
                if (file.ContentLength > 0)
                    string fileName = Path.GetFileName(file.FileName);
                    var path = Path.Combine(imgPath, fileName);
                    file.SaveAs(path);
                    imageUrl = string.Format("~/Uploads/{0}", fileName);
            return Json(new { img = imageUrl, thumb = imageUrl });
Dropzone:
Dropzone.options.wmUpload = {
        paramName: "file",
        parallelUploads: 3,
        url: '/DesktopModules/MVC/DropzoneHandler/Dropzone/Upload',
        autoProcessQueue: true,
        addRemoveLinks: true
Notice that in the error message it indicates the error is "in '/desktopmodules/mvc/DropzoneHandler' Application", meaning that a separate application was created that's not the root application. Look in IIS for a new application or virtual directory setup in the path and then delete it. Visual Studio will "helpfully" do this for you sometimes when setting up projects.
