Internal property is accessed from another assembly
DNN 9.9.1
I'm trying to create an extended version of the standard Html module.
When I copy the module VS project and update the namespace & assembly name I get the error "'Globals.DependencyProvider' is inaccessible due to its protection level" in HtmlTextController, ln 54.  This makes sense as it is marked as 'internal' in the DotNetNuke.dll assembly.
What I don't understand is how the standard HTML doesn't have this problem - it is also in a separate assembly? But I can compile the standard HTML project without errors.
If I change my assembly name back to DotNetNuke.Modules.Html the error message goes away.  But if I change it to say, DoteNetNuke.Modules.MyHtml, it reappears.
I'm missing something fundamental here. Any thoughts please?
The reason was DotNetNuke.dll had an InternalsVisibleTo attribute in AssemblyInfo.cs for this and a few other modules:
[assembly: InternalsVisibleTo("DotNetNuke.Modules.Html")] // Once Globals is refactored to Dependency Injection we should be able to remove this
For reference, this is in line 43 of <code>AssemblyInfo.cs</code> in the main "Library" project.
The plan is currently to support dependency injection in business controller classes in 10.0.0, which would allow <code>HtmlTextController</code> to add a constructor with an overload accepting an <code>INavigationManager</code> and the framework would automatically supply that.
That said, in this scenario, the <code>HtmlTextController</code> is being created by the modules, so it doesn't necessarily need to use <code>Globals.DependencyProvider</code> in that scenario, but can use the <code>DependencyProvider</code> exposed to the modules. I've submitted pull request #4786 which implements those changes.
For your scenario, you can either leave <code>HtmlTextController.NavigationManager</code> set to <code>null</code> when instantiated by the platform or you can inherit from the core <code>DotNetNuke.Modules.Html.HtmlTextController</code> class and use its <code>protected</code> <code>NavigationManager</code> property. Or just remove the <code>INavigationManager</code> usages and fall back to the deprecated <code>Globals.NavigateURL</code> for now.
Hope it helps!
