Preserving query string parameters during portal navigation
Hello,
I am porting several modules developed in DNN 7 to DNN 9.11.
Former colleagues modified the (sealed) "DotNetNuke.Common.Globals.NavigateURL" class to introduce a collection of parameters to be added and stored in query string.
Is there a smart way to do the same thing with DNN 9, possibly without modifying the DNN code base?
Seek
Hopefully someone with more experience in the community can better answer, but you want to implement INaviationManager.
I relied heavily on these two threads:
https://dnncommunity.org/...ss-controller-class/
https://dnncommunity.org/...s/navigationmanager/
If you want to see it implemented in the Community Forums module:
https://github.com/DNNCom...ices/UrlNavigator.cs
If you can provide an example of the sort of customization that was previously done, we could probably give you an alternative fairly easily. I'm imagining that you could move your customized methods out into another class that takes an INavigationManager (and/or wraps Globals.NavigateURL, depending on how its used).
Posted By Brian Dukes on 7/26/2024 7:02 PM
Sure, here my code based on old DNN 7.4.2
[CODE]
public static string NavigateURL(int tabID, bool isSuperTab, PortalSettings settings, string controlKey, string language, string pageName, params string[] additionalParameters)
    string url = tabID == Null.NullInteger ? ApplicationURL() : ApplicationURL(tabID);
    if (!String.IsNullOrEmpty(controlKey))
        url += "&ctl=" + controlKey;
    if (isSuperTab)
        url += "&portalid=" + settings.PortalId;
    /* Introduction of a collection of query string elements to be preserved during portal page navigation.
     * A collection of keys is defined, where each key is the name of a query string parameter. For each navigation request,
     * this class checks the collection and, for each element, verifies its presence in the query string of the current request;
     * if the element is found, a corresponding entry in the query string will be inserted in the generated URL.
     * This mechanism allows reproducing the behavior that was present when the information about the current company was part
     * of the HTTP alias: the "CompanySelector" component will take care of keeping the information updated.
     * If one of the parameters of the current request is a URL, the list of its parameters is merged with the list of the
     * request parameters. Consequently, the value retrieved from the QueryString property is a comma-separated list of all
     * the parameter values. In this case, I assume that the parameter representing a URL is always the last in the list
     * and consider only the value of the first occurrence of the parameter.
    if (HttpContext.Current != null)
        foreach (string parameterName in QueryStringParametersToBePreserved)
            int indexOfParameter = HttpContext.Current.Request.Url.Query.ToUpper().IndexOf(parameterName.ToUpper());
            /* Must check:
             * - generated URL does not contain the current parameter
             * - the current parameter does not in additional parameters (which must prevail)
            if (indexOfParameter != -1 &&
                !url.ToUpper().Contains(parameterName.ToUpper() + "=") &&
                (additionalParameters == null || !additionalParameters.Any(p => p != null && p.ToUpper().StartsWith(parameterName.ToUpper() + "="))))
                string substringAfterParameter = HttpContext.Current.Request.Url.Query.Substring(indexOfParameter);
                int indexOfAmpersand = substringAfterParameter.IndexOf("&");
                string nameAndValue;
                if (indexOfAmpersand != -1)
                    nameAndValue = substringAfterParameter.Substring(0, indexOfAmpersand);
                else
                    nameAndValue = substringAfterParameter;
                url += "&" + nameAndValue;
    TabInfo tab = null;
    if (settings != null)
        tab = TabController.Instance.GetTab(tabID, isSuperTab ? Null.NullInteger : settings.PortalId, false);
    //only add language to url if more than one locale is enabled
    if (settings != null && language != null && LocaleController.Instance.GetLocales(settings.PortalId).Count > 1)
        if (settings.ContentLocalizationEnabled)
            if (language == "")
                if (tab != null && !string.IsNullOrEmpty(tab.CultureCode))
                    url += "&language=" + tab.CultureCode;
            else
                url += "&language=" + language;
        else if (settings.EnableUrlLanguage)
            //legacy pre 5.5 behavior
            if (language == "")
                url += "&language=" + Thread.CurrentThread.CurrentCulture.Name;
            else
     * I place additional parameters at the end of the generated URL: in some cases, the last parameter passed to this method is a URL;
     * if this URL itself has parameters, these are mistakenly interpreted as parameters of the generated URL, not of the parameter itself,
     * causing interpretation errors.
    if (additionalParameters != null)
        url = additionalParameters.Where(parameter => !string.IsNullOrEmpty(parameter)).Aggregate(url, (current, parameter) => current + ("&" + parameter));
    if (Host.UseFriendlyUrls || Config.GetFriendlyUrlProvider() == "advanced")
        if (String.IsNullOrEmpty(pageName))
            pageName = glbDefaultPage;
        url = (settings == null) ? FriendlyUrl(tab, url, pageName) : FriendlyUrl(tab, url, pageName, settings);
    else
        url = ResolveUrl(url);
    return url;
[CODE]
It looks to me like you should be able to wrap the existing <code>NavigateURL</code> functionality, instead of rewriting it. Something like this:
<code>public class NavigationUtility {
private readonly INavigationManager navigationManager;
public NavigationUtility(INavigationManager navigationManager)
    this.navigationManager = navigationManager;
public string NavigateURL(int tabID, bool isSuperTab, PortalSettings settings, string controlKey, string language, string pageName, params string&#91;&#93; additionalParameters)
    var allParameters = new List<string>(additionalParameters ?? Array.Empty&ltstring>());
            /* Must check: the current parameter does not in additional parameters (which must prevail) */
                else
                allParameters.Add(nameAndValue);
    return this.navigationManager.NavigateURL(tabID, isSuperTab, settings, controlKey, language, pageName, allParameters.ToArray());
</code>
Thanks!
What do you think is better to do?
Inherit the class
Modify the existing DNN code
What else?
Posted By Seek78 on 7/30/2024 8:55 AM
Thanks!
Inherit the class
What else?
I mean, I want it as default for all URL visited in the portal.
To affect all URLs generated, you would need to modify the core code, or create your own friendly URL provider.
Posted By Brian Dukes on 7/31/2024 3:22 PM
Could you provide come examples?
S.
Maybe something like this (and then adjust the <code>friendlyUrl</code> section of the <code>web.config</code> to point to your provider):
using System;
using DotNetNuke.Abstractions.Portals;
using DotNetNuke.Common;
using DotNetNuke.Entities.Tabs;
using DotNetNuke.Services.Url.FriendlyUrl;
namespace overridednnurls
    public class SpecialFriendlyUrlProvider : FriendlyUrlProvider
        private static readonly string[] QueryStringParametersToBePreserved = { "CompanySelector", };
        public override string FriendlyUrl(TabInfo tab, string path)
            return DNNFriendlyUrlProvider.Instance().FriendlyUrl(tab, AdjustParameters(path));
        public override string FriendlyUrl(TabInfo tab, string path, string pageName)
            return DNNFriendlyUrlProvider.Instance().FriendlyUrl(tab, AdjustParameters(path), pageName);
        public override string FriendlyUrl(TabInfo tab, string path, string pageName, string portalAlias)
            return DNNFriendlyUrlProvider.Instance().FriendlyUrl(tab, AdjustParameters(path), pageName, portalAlias);
        public override string FriendlyUrl(TabInfo tab, string path, string pageName, IPortalSettings settings)
            return DNNFriendlyUrlProvider.Instance().FriendlyUrl(tab, AdjustParameters(path), pageName, settings);
        private static string AdjustParameters(string path)
            if (!Uri.TryCreate(path, UriKind.Relative, out var url))
                return path;
            if (HttpContextSource.Current != null)
                    int indexOfParameter = HttpContextSource.Current.Request.Url.Query.IndexOf(parameterName, StringComparison.OrdinalIgnoreCase);
                    if (indexOfParameter != -1 && !path.ToUpperInvariant().Contains(parameterName.ToUpperInvariant() + "="))
                        string substringAfterParameter = HttpContextSource.Current.Request.Url.Query.Substring(indexOfParameter);
                        int indexOfAmpersand = substringAfterParameter.IndexOf('&');
                        else
                        path += "&" + nameAndValue;
            return path;
