Replace Deprecated in Platform 9.4.2
Mac
Dealing with replacement of two depcrecated methods somewhat releated in our code.
This first one, I see has its own threads, so I will avoid it.
'Public Overloads Function NavigateURL() As String' is obsolete: 'Deprecated in Platform 9.4.2.
The one I am interested in is commonly used as a paramter to the first:
'Function GetCurrentPortalSettings() As PortalSettings' is obsolete: 'Deprecated in Platform 9.4.2.
I replaced
Dim PortalSettings As Entities.Portals.PortalSettings = Entities.Portals.PortalController.Instance.GetCurrentPortalSettings
With the new interface version
Dim PortalSettings = Entities.Portals.PortalController.Instance.GetCurrentSettings.
But this property that was available before is no longer.- PortalSettings.ActiveTab.TabID
 Where can I find missing properties?
I would use <code>TabController.CurrentPage</code> in place of <code>PortalSettings.ActiveTab</code>.
Mac
Thanks, now to get back to the seemingly more difficult one. NavigateURL() As String' is obsolete: 'Deprecated in Platform 9.4.2.
Did not see a way to mark this as Solved, maybe we dont have that feature.
Some discussion of this can be found at https://dnncommunity.org/forums/aft/794/afpg/2
Here is an excerpt that (I hope) contains the replacement process. The entire thread is worth reading. And, it would be nice if something about this got added to dnndocs.com. I'll leave that to someone else ...
26 Jul 2020 08:42 PM
Here is a full synopsis of how to move from the old NavigateURL to the new method
References for your project must be made to:
DotNetNuke.Abstractions
Microsoft.Extensions.DependencyInjection
Microsoft.Extensions.DependencyInjection.Abstractions
* the dlls can be found in the bin directory
DotNetNuke.Abstractions is required for INavigationManager and must be declared above as an imports or using (depending on language) before your class definition
Microsoft.Extensions.DependencyInjection is required as an imports/using so that you can call on the PortalModuleBase.DependencyProvider
Each of these returns a string which you can then do redirects with or whatever.
The old way - Common.Globals.NavigateURL(PortalSettings.ActiveTab.TabID, "YourControlKey", "mid=" & CStr(ModuleId))
The new way - DependencyProvider.GetRequiredService(Of INavigationManager).NavigateURL(PortalSettings.ActiveTab.TabID, "YourControlKey", "mid=" & CStr(ModuleId))
If you want to circumvent the call to DotNetNuke.Abstractions you can call it like this:
DependencyProvider.GetRequiredService(Of Abstractions.INavigationManager).NavigateURL(PortalSettings.ActiveTab.TabID, "YourControlKey", "mid=" & CStr(ModuleId))
Mac, you'll need to use the <code>INavigationManager.NavigateURL</code> method instead. How you obtain an <code>INavigationManager</code> instance varies based on your development paradigm.
At a high level, the answer is that you'll request one from the dependency injection container. If you're using MVC controllers or Web API controllers, you can just add a parameter to your controller's constructor and the framework will supply that dependency automatically. Here's a Web API controller example:
<code>Imports DotNetNuke.DependencyInjection
Imports Microsoft.Extensions.DependencyInjection
Public Class MyController
    Inherits DnnApiController
    Private ReadOnly navigationManager As INavigationManager
    Public Sub New(ByVal navigationManager As INavigationManager)
        Me.navigationManager = navigationManager
    End Sub
End Class</code>
You can see a fuller discussion with more examples at https://dnncommunity.org/forums/aft/2002#5875. Hope it helps!
Mac
Very good info guys, thanks.
I had read through the thread referenced and it seemed to be a very complex solution. I think that because our design is using web forms rather than mvc, maybe it simplified my fix. I almost dont trust it yet . I had found the reply that Joe mentioned and used it to make this modification and it worked. I will have to add the references and imports to multiple modules where we were using the NavigateURL. If there is a flaw that you can see here, please let me know.
Private Sub lbtnGoHome_Click(sender As Object, e As EventArgs) Handles lbtnGoHome.Click
        Dim lcPortalController As New DotNetNuke.Entities.Portals.PortalController
         Dim lcPortalInfo As New DotNetNuke.Entities.Portals.PortalInfo
         lcPortalInfo = lcPortalController.GetPortal(Me.PortalId)
          Response.Redirect(DependencyProvider.GetRequiredService(Of                         Abstractions.INavigationManager).NavigateURL(lcPortalInfo.HomeTabId), False)
          ' replaced .... Response.Redirect(DotNetNuke.Common.NavigateURL(lcPortalInfo.HomeTabId, False))
