ReturnURL on a custom authentication provider
I have a custom authentication provider that is working well but it doesn't support ReturnURL seems.
The Login class inherits from AuthenticationLoginBase and it has a piece of code like this:
                           UserLoginStatus loginStatus = validStatus == UserValidStatus.VALID ? UserLoginStatus.LOGIN_SUCCESS : UserLoginStatus.LOGIN_FAILURE;
                           if (loginStatus == UserLoginStatus.LOGIN_SUCCESS)
                               SetLoginDate(username);
                               // Raise UserAuthenticated Event
                               var eventArgs = new UserAuthenticatedEventArgs(userInfo, userInfo.Email, loginStatus, config.DNNAuthName)
                                   Authenticated = true,
                                   Message = "User authorized",
                                   RememberMe = false
                               OnUserAuthenticated(eventArgs);
                               if (Request.Params["RelayState"] != null)
                                   string redirectUrl = HttpUtility.UrlDecode(Request.Params["RelayState"]);
                                   Response.Redirect(redirectUrl);
Notice how it calls OnUserAuthenticated(...). The problem is that after this call it never comes back, so all code that goes after this line is not executed.
And so the RelayState parameter that contains the url the user should be redirected to is never done.
Is there a way to force DNN to know that it has to return to a specific url after the login is completed? if so how?
Vicenç Masanas
Disgrafic ITec SL Banyoles - Spain
Normally that event is called last.  Maybe you can create an alternative method async to run the same logic in your provider?
