Rich Text Editor for MVC/Razor module
Hi there,
I think this is an old question from the old forum years ago but just wanna check if there is an update regarding a Rich Text Editor for build a MVC/Razor module similar to something we build a webform module? Currently I use tinyMCE however it doesn't link to the site media which is not quite convenient...
Thank you
I'd like to know about this too~
As far as I know there is no support for a Rich Text Editor in MVC modules, this is something we should create an issue on GitHub. It should be something as simple as
[code]
@Html.RichTextEditor()
[/code]
I'm not sure how difficult this would be to implement but documenting the missing feature is important
Same problem here... need a Rich Text Editor in MVC module
Is there any documentation? solution we can use?
