Upgrading from 9.1.1 to 9.4.4 and Globals.NavigateURL
Ana
I am planning to upgrade my DNN site (WebForms) from 9.1.1 to 9.4.4. I am doing a test run on local machine. After I upgraded I see the following warning when I compiled my custom modules. Going to NaviagateURL documentation doesn't give any information on what replaced it. What replaced it?
Globals.NavigateURL(int, string, params string[])' is obsolete: 'Deprecated in Platform 9.4.2. Scheduled removal in v11.0.0.
Ana,
I had the same "problem". Please refer to this forum post - it should give you the answer...
Don't hesitate to ask if you have further questions.
Ana
Posted By Michael Tobisch on 29 Feb 2020 10:59 AM
Ana,
Thanks Michael for the reply. The link you added points to this post itself. Can you please send me the right one.
Ana, I believe that post is https://dnncommunity.org/forums/aft/794. The short version is to use <code>INavigationManager.NavigateURL</code> instead. You'll need to use Dependency Injection to access an implementation of the <code>INavigationManager</code> interface.
Hope it helps!
Ana
Posted By Brian Dukes on 02 Mar 2020 09:26 AM
Hope it helps!
Thanks Brian! I am trying get the example you pointed compile and I am getting errors about netstandard. What am I missing?
CS0012    The type 'IServiceProvider' is defined in an assembly that is not referenced. You must add a reference to assembly 'netstandard, Version=2.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51'
You'll need to make sure your project is referencing .NET 4.7.2 (or later), and that you have the right version of the DotNetNuke.Abstractions and DotNetNuke.DependepcyInjection NuGet packages.
Ana
Posted By Brian Dukes on 02 Mar 2020 11:36 AM
I have the following in packages.config (site is not letting me copy paste the config file contents):
  DotNetNuke.Core, version 9.4.0.156-alpha, targetFramework net472
  DotNetNuke.DependencyInjection, 9.4.0.156-alpha, net472
  Microsoft.Extensions.DependencyInjection, 2.1.1, net472
 icrosoft.Extensions.DependencyInjection.Abstractions, 2.1.1, net472
And target framework is .NET Framework 4.7.2.
You'll want to reference the 9.4.4 packages for DNN.  According to https://github.com/dotnet...uecomment-349163872, you may need to update Visual Studio, and it may help to add a <code>Reference Include="netstandard"</code> line into your project file.
Ana
Posted By Brian Dukes on 02 Mar 2020 12:07 PM
Thanks Brian, I updated my Visual Studio and everything compiles fine. But, I use Globals.NavigateURL in schedulers which don't extend PortalModuleBase. Also, in few of the modules we have a static methods which return the URL using Globals.NavigateURL, which can be accessed both by Schedulers, ascx. Is there a way to get hold of INavigationManager instance in these scenarios?
Ana, there doesn't appear to be a way in DNN 9.5.0 for you to access an INavigationProvider instance from a scheduled task. Thank to your post, we'll investigate and provide a resolution. You can follow progress at https://github.com/dnnsof...Platform/issues/3602
