9.4.4 RC1 upgrade Issue
 24 Subscribed to this forum
First off I like to thank the fast response to this latest update.  Just flat out AWESOME!  Nice work from the reporting to the testing all the way to getting this release to the masses to test.  I applaus you and encore!
Everything seems stable and upgraded ok I just found one error in logs so far.  I am not sure if this issue is only for this one instance as I update it from one RC to the next as it is my beta site but I did get one error while upgrading.
It may not be worth reporting so just wanted to share it here to see if it is only my one installation.  I have a few other sites I may be able to test the update on once I back them up.
AbsoluteURL /install/upgradewizard.aspx DefaultDataProvider DotNetNuke.Dat
AbsoluteURL:/install/upgradewizard.aspx
ExceptionGUID:67271f0e-75f1-40d0-91ca-65adfb263322
ExceptionHash:EcKpU9IhgBxklkM1klL0uU7Y5EQ=
Message:The process cannot access the file '....\install\upgradestat.log.resources.txt' because it is being used by another process.
StackTrace
InnerMessage:The process cannot access the file '...\Install\upgradestat.log.resources.txt' because it is being used by another process.
InnerStackTrace:
   at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
   at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
   at System.IO.StreamWriter.CreateFile(String path, Boolean append, Boolean checkHost)
   at System.IO.StreamWriter..ctor(String path, Boolean append, Encoding encoding, Int32 bufferSize, Boolean checkHost)
   at System.IO.StreamWriter..ctor(String path, Boolean append)
   at System.IO.File.CreateText(String path)
   at DotNetNuke.Services.Install.UpgradeWizard.OnLoad(EventArgs e)
Do you have antivirus running that is scanning those directories?
I do have an antivirus application on the server however it has never shown an error like this in the past.
Always make sure you exclude antivirus from scanning any directory within your IIS site and ALSO exclude it from scanning .Net temp folders
Found this document I will configure it as directed and run a few more installations.
https://support.microsoft...ning-in-asp-net-apps
Yes, that is a good article. I don't run any antivirus on my web servers
Microsoft Defender automatically puts all the rules in place for whatever roles are installed on the server as I investigated that as well. When the Web Server role is installed and Windows Defender is enabled all the AV exception rules are created as needed.
This server had not had the exceptions setup and is using a paid AV which is probably related to this issue.
I upgraded a 9.3.0 to 9.4.4 successfully no errors on this same machine instance. Updated, removed, deleted users, created moved some pages around... still doing stuff on them. Installed latest DNN Events 7.4 from 6.2 successfully. So far so good other than an issue with updating the version of a few modules from 9.3.2 to 9.4.4 which is not a big deal if it is even an issue I just reported on github.
thank you
Cody
