HTML Module
Page 2 of 2 << < 12
Two things.
1. If you set it to Direct Publish, right below that you can specify to apply those settings to the module, page or site. I selected site and modified that setting for all html modules.
2. The HTML module will not display outside of edit mode if they do not have any content in them. Even if you change the heading to say something other than Text/HTML, until you edit the content they will only be visible in edit mode.
Carolyn,
I can't thank you enough for setting me on the right track. With your help, I was able to figure it out via process of elimination. Have a great weekend!
Thanks,
Jesse
I'm so glad you were able to fix the problem!  I'm sure other people will run across this issue and now we know how to fix it! :-)
Page 2 of 2 << < 12
