Account Login Module issue
For some reason, when logging onto my main website the account login module is showing "Email Address" instead of "User name". The site is setup to use the user name and in fact you are required to enter the username as entering the email address doesn't work. I have a child site on my server and for that site the Account Login Module is showing "Username".  Only difference between the two that I can see is the main site uses a seperate Login page whereas the child site uses the popup login window without a seperate
Not sure when it started showing this way but did notice it awhile ago and just ignored it at the time. Would like to figure out how to change this. Not sure if it started occuring when we migrated our site from DNN Evoq to DNN Platform.
Does anyone know how to fix this?
Two things come into my mind:
  1. Could be a custom login page, where the label is "Email Address" - should be easy to change
  2. Could be in the language resource fles for the site
It is a custom page however I added the Account Login module from DNN not a custom module.
I checked the resource files and when I go into Site Settings - Languages - Global resources - shared resources the Username.text field value is Username. Is this setting configurable for an individual portal? One of the portals does show as Username on the account login module.
I think Michael's suggestion about localization might be the right answer.  Here's a video to show you where/how to find that value to verify:
https://www.youtube.com/w...VcCY2yzhTZk&index=14
Thanks that fixed it. Took awhile to find the setting that I had to change but it worked.
