add a module to page using sql
Hi is it possible to add a module to a page via sql.  for e.g. I need to replace a deprecated module that has many hundreds of records on 300 + pages over several portals with a replacement module.
My thinking is!
  1. Use a select query to get each tabid where a module currently exists (I have a query which will do that)
  2. Use this list of tab id's to add a replacement module to each page (ideally in the same pane etc).
  3. Insert query to copy data from the original module table and insert into the new modules table (passing the new moduleid).
  4. Delete old modules when successful
I have successfully tested step 1 to return IDs,
I have manually added a replacement module to a single test page and successfully migrated data across as in step 3. The hard bit, of course, is whether I can add modules this way.
Hope this makes some sense
Stuart,
I did this once with a lot of testing, trial & error, etc. etc. - but it worked finally. I converted Nuntio Content to HTML modules this way. If you want to look at the scripts, you can find them in a thread in the German Usergroup forum, in the third post on page 2: http://www.dnn-usergroup..../topic/Default.aspx.
I did not add the new modules to the pages (and I did not delete them after the process), but replaced the ModuleDefId in the Modules table. Therefore I did not touch the TabModules table.
Note:
  • Do it in a testing environment before you run the SQL scripts on the production site.
  • Make backups (early and often, always before you try a new step)
  • Think about converting the content and the module settings.
  • Restart the application pool after changing something in the database, otherwise you see cached data and your changes are not reflected (immediately) on the site.
Cheers Michael, I will look at your scripts and will definitely be testing on our dev server first.
Stuart
Posted By Stuart on 27 Feb 2020 03:37 AM
Stuart
Could post your solution in here please? That could be helpful for people that will try the same in the future :-)
