AI, LLMs, and Building a DNN Module
Page 2 of 2 << < 12
Thanks man I really appreciate this brother thanks man!
I have been increasingly using GitHub copilot. Particularly for mundane things where previously I used code templates and snippets. I also admit I’m not a bleeding edge coder and I sometimes point at a block of code and ask “how do I optimize this?” Or “can I avoid duplication in this code?”
I review what gets generated and sometimes it’s junk but often it helps. Things improved dramatically after I added a copilot-instructions.md that I tailored for DNN and to the forums module. That provides the “rules of the road”. For instance, which net and c# version, coding style, etc.
I have still not adopted agents nor do I blindly accept AI-generated anything. I use it as a starting point but everything still needs human oversight.
I'm moving into GitHub pilot and for small "non-complex" code methods, it's great and I now use it just to check my methods. It's a tool and a good one. It you let it take too much control, it makes a mess. It's a blind hammer and you need to point it at the nail, but once you do, it's a great time saver. (I still not 100% trusting with it).
As for CSS and design, which is not my job, I find it great for giving ideas. When using a framework like Bulma, it good...... but be prepared for a mess of CSS that takes forever and that you don't need if you let it go wild doing every little thing.
I mostly use "Ask" mode, but I often switch when I have confidence it know what it's doing.
Starting a chat with simple content and rules is often a great way to target it's answers, but it means creating one for each project. Here is an example of what I use on one project, but be it needs adapting when you find it still gets thing wrong.
Example Context Text:
mode: Agent
# DNN/Razor Legacy System Development Assistant
## SYSTEM CONTEXT
This is a DNN (DotNetNuke) system with older Razor syntax requirements:
- Razor code must be compatible with legacy patterns
- It uses RazorEngine to compile the razor templates. https://github.com/Antaris/RazorEngine
- Use `@@media` instead of `@media` in CSS
- Use `@HtmlOf("
myhtml
")` instead of `Html.Raw()`
- System uses Rocket AJAX framework with Simplisity.js https://github.com/Rocket-CDS/DNNrocket
- Documentation: https://docs.rocket-cds.org/
- Simplicity Tokens: https://docs.rocket-cds.o...or-tokens-simplisity
## UNCERTAINTY PROTOCOL
- If uncertain about any fact, code structure, or technical detail, you MUST say "I don't know" or "I'm not certain"
- Never guess, assume, or fabricate information to fill gaps
- Never state something as fact unless you can verify it from provided context or files
- If making an assumption, explicitly label it: "I'm assuming that..."
- When lacking information, ask for clarification rather than proceeding with guesswork
- Confidence in response must match actual certainty level
- Better to say "I need to read the file to know for sure" than to guess about code structure
## EDITING PROTOCOL
- Before making changes, explain what you are going to do and request confirmation
- Include 3-5 lines of context before and after the target change
- Wait for approval before executing any replace_string_in_file operations
- After making changes, read back the result to confirm it worked correctly
## INCREMENTAL APPROACH
- Break complex tasks into smaller, verifiable steps
- Complete one change at a time and verify before proceeding
- Ask which specific change to make first when multiple options exist
- Test each step before moving to the next
## TESTING PROTOCOL
- Do NOT launch localhost server for testing
- User will carry out tests on hosted web server
- Focus on code accuracy rather than local testing
- Never compile when you only change razor files.
## CLARIFICATION POLICY
If unsure about anything, ask for clarification rather than making assumptions.
mode: Agent
## SYSTEM CONTEXT
- Use `@HtmlOf("
myhtml
## EDITING PROTOCOL
## TESTING PROTOCOL
Well.. as you can see the forum editor keeps screwing the html to html, but you get the idea.
Posted By David Lee on 10/9/2025 8:47 AM
David, xml/html pasting is (hopefully) fixed in newest forums version but it has not yet been installed on this site.
Page 2 of 2 << < 12
