CCPA/GDPR Cookie Consent Module
While researching, I discovered that in order to be CCPA/GDPR compliant, the cookie consent module needs to track IP and consent and this data needs to be retrievable at any point if asked for. I am currently looking for a cookie consent module with these capabilities that is compatiable with DNN 9.5 and ultimately DNN 9.6.1. I've already looked at the following modules and these do not have the tracking functionality I am looking for:
https://store.dnnsoftware...sive-for-dnn-6-7-8-9
https://store.dnnsoftware...e-pscookiecompliancy
https://store.dnnsoftware.../gdpr-cookie-consent
Thoughts on where to look?
Thanks!
By default there is a cookie consent iin DNN : Site settings - Site behavior - Privacy.
The exact functionality has been improved in several versions. I'd recommend to upgrade DNN as a first step. If there are still issues, you can log them in Github.
Having said that: I doubt that you are required to track IP as that is one of the parameters that should be anonimized. For example Google analytics als has the option to not log the IP. But I am no lawyer :-)
