compatibility issue between the DotNetNuke SQL Reporting Services (SSRS) Module and DNN version 10.1.2
Hello Team,
I hope this message finds you well.
I am reaching out to report a compatibility issue between the DotNetNuke SQL Reporting Services (SSRS) Module and DNN version 10.1.2.
After upgrading our DNN portal to version 10.1.2, we began encountering the following error when attempting to load pages that include the SSRS Module:
  error:DotNetNuke.Framework.PageBase - An error has occurred while loading page. System.MissingMethodException: Method not found: 'DotNetNuke.Entities.Tabs.TabInfo DotNetNuke.Entities.Tabs.TabController.GetTab(Int32)'. at BS.Modules.SSRS.View.Page_Load(Object sender, EventArgs e) at System.Web.UI.Control.OnLoad(EventArgs e) at DotNetNuke.Entities.Modules.PortalModuleBase.OnLoad(EventArgs e) at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Control.d__246.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Util.WithinCancellableCallbackTaskAwaitable.WithinCancellableCallbackTaskAwaiter.GetResult() at System.Web.UI.Page.d__523.MoveNext() [ERROR] DotNetNuke.Services.Exceptions.Exceptions - ~/Default.aspx?tabid=2494&error=Method+not+found%3A+%27DotNetNuke.Entities.Tabs.TabInfo+DotNetNuke.Entities.Tabs.TabController.GetTab(Int32)%27.&content=0 System.MissingMethodException: Method not found: 'DotNetNuke.Entities.Tabs.TabInfo DotNetNuke.Entities.Tabs.TabController.GetTab(Int32)'. at BS.Modules.SSRS.View.Page_Load(Object sender, EventArgs e) at System.Web.UI.Control.OnLoad(EventArgs e) at DotNetNuke.Entities.Modules.PortalModuleBase.OnLoad(EventArgs e) at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Control.d__246.MoveNext()
It appears that the method <code>TabController.GetTab(Int32)</code> is no longer available or has been modified in DNN 10.1.2, causing the SSRS module to fail during page load.
As this module is essential for our portal’s reporting functionality, we would appreciate your assistance in confirming whether an updated version of the SSRS module is available, or if any workaround or code modification is recommended to restore compatibility with DNN 10.1.2.
Please let us know the best course of action to resolve this issue.
Thank you for your time and support.
Kind regards,
Well Ai doesn't find it, you need to use the portalid, in GitHub this was last changed in 2023. Off the top of my head, I can't remember using GetTab() method without the portalid.
Get in touch with the module creators and see if they have a DNN10 verison.
AI return...
Summary
The method DotNetNuke.Entities.Tabs.TabController.GetTab(Int32) that you're looking for does not exist in the DotNetNuke codebase.
The minimum required parameters for the GetTab method are:
• tabId (int) - The ID of the tab you want to retrieve
• portalId (int) - The ID of the portal containing the tab
