Could not load type with GDPR consent viper
NVG
Hello!
Recently I inherited the task of applying GDPR compliance to a website at my company. Some years ago, another - now gone - employee researched dnn plugins and got GDPR compliance viper, and we have the licenses purchases and all.
I can install the plugin (version 1.0.2) and add it to the main page, but when I go into the module administration it doesn't load and the log shows this error:
DotNetNuke.Services.Exceptions.Exceptions - System.Web.HttpParseException (0x80004005): Could not load type 'DotNetNuke.Admin.Modules.ModuleLocalization'. ---> System.Web.HttpParseException (0x80004005): Could not load type 'DotNetNuke.Admin.Modules.ModuleLocalization'. ---> System.Web.HttpException (0x80004005): Could not load type 'DotNetNuke.Admin.Modules.ModuleLocalization'.
   at System.Web.UI.TemplateParser.GetType(String typeName, Boolean ignoreCase, Boolean throwOnError)
   at System.Web.UI.TemplateParser.ProcessInheritsAttribute(String baseTypeName, String codeFileBaseTypeName, String src, Assembly assembly)
   at System.Web.UI.TemplateParser.PostProcessMainDirectiveAttributes(IDictionary parseData)
   at System.Web.UI.TemplateParser.ProcessException(Exception ex)
   at System.Web.UI.TemplateParser.ParseStringInternal(String text, Encoding fileEncoding)
   at System.Web.UI.TemplateParser.ParseString(String text, VirtualPath virtualPath, Encoding fileEncoding)
   at System.Web.UI.TemplateParser.ParseFile(String physicalPath, VirtualPath virtualPath)
   at System.Web.UI.TemplateParser.ParseInternal()
   at System.Web.UI.TemplateParser.Parse()
   at System.Web.Compilation.BaseTemplateBuildProvider.get_CodeCompilerType()
   at System.Web.Compilation.BuildProvider.GetCompilerTypeFromBuildProvider(BuildProvider buildProvider)
   at System.Web.Compilation.BuildProvidersCompiler.ProcessBuildProviders()
   at System.Web.Compilation.BuildProvidersCompiler.PerformBuild()
   at System.Web.Compilation.BuildManager.CompileWebFile(VirtualPath virtualPath)
   at System.Web.Compilation.BuildManager.GetVPathBuildResultInternal(VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile, Boolean throwIfNotFound, Boolean ensureIsUpToDate)
   at System.Web.Compilation.BuildManager.GetVPathBuildResultWithNoAssert(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile, Boolean throwIfNotFound, Boolean ensureIsUpToDate)
   at System.Web.UI.TemplateControl.LoadControl(VirtualPath virtualPath)
   at DotNetNuke.UI.Modules.WebFormsModuleControlFactory.CreateModuleControl(TemplateControl containerControl, ModuleInfo moduleConfiguration)
   at DotNetNuke.UI.Modules.ModuleControlFactory.LoadModuleControl(TemplateControl containerControl, ModuleInfo moduleConfiguration)
   at DotNetNuke.UI.Skins.Skin.InjectModule(Pane pane, ModuleInfo module)
I'm guessing it's a version issue but I'm not knowledgeable enough about DNN to move forward. I tried searching for the module in question without results and I tried resetting language settings (it blew the test server).
Any help is much appreciated!
Edit:
GDPR Consent Viper I'm using is version 1.0.2
DNN is DNN 8.0.4
I would use the default GDPR compliance of DNN.
My guess is that the purchased module was at a time when DNN did not have this feature on board.
Settings - Site settings - Site behavior - Privacy
My first guess would be a version problem.
1. What version of DNN are you using?
2. What version of the module are you using?
I use that module on one installation without any problems. Plus, they are pretty good with support.
NVG
Posted By Tycho de Waard (SU) on 04 Aug 2021 04:21 AM
I'm afraid our version of DNN is older than this feature as we use DNN8 and I can't find the "privacy" menu
NVG
Posted By Joe Craig on 04 Aug 2021 08:23 AM
Oh, I thought I added all the versions in my first post, sorry.
Im using DNN 8 and GDPR Cookie Consent Viper 1.0.2
Version problem was my guess, but I couldn't find info about this specific problem and I believe the module is compatible with DNN 7 through 9
I'd check with the developers and ask which version of their module you should be using.
I'd also make plans ASAP to upgrade. You are woefully out of date and vulnerable to security issues that have been fixed subsequently. And, DNN 9.x is quite superior to what you are using.
