Countdown module / script
I'm looking for a free countdown module / script
any suggestions?
I haven't seen on of these in years.
I'm sure that you can find a simple javascript to do the time part.
To make this more user friendly in terms of configuration, I'd probably stick this into a 2sxc app and use the App Settings for configuration of the script.
there are a number of free jQuery extensions, depending on your needs.
Bing or Google is your friend ;)
thanks did the trick with open content & javascript
