Dependency Injection (DI) issue in classes inheriting from ModuleSearchBase
Hello everyone,
I'm currently developing a module for DNN and I've encountered a problem regarding Dependency Injection (DI) within my search components.
The Core Problem
My module's search controller class inherits from <code>ModuleSearchBase</code>.
Challenge: I am unable to use Constructor Injection to inject my required services (such as <code>IMyService</code> or core DNN services) into this class.
It appears that since <code>ModuleSearchBase</code> is a legacy base class, it is not instantiated by the core DNN DI container, meaning its constructor is not called, and thus injection fails. This often happens because the search indexing process runs in a context where a standard HTTP Request Scope is not available.
My Question
In DNN version 9.x (specifically 9.13.9), what is the best and most recommended approach for accessing services registered via DI (which I have registered in my <code>IDnnStartup</code> implementation) inside a class that inherits from <code>ModuleSearchBase</code>?
Should I rely on one of the following patterns?
  1. Singleton Helper Class: Creating a Singleton helper class that resolves the services during application startup, making them globally accessible.
  2. Scoped Resolution: If my required services have Scoped Dependencies (e.g., a database context), how can I reliably create a new, dedicated <code>IServiceScope</code> within the search context to properly resolve and dispose of these services?
I have attempted methods based on resolving the provider via <code>HttpContextSource.Current?.GetScope()?.ServiceProvider</code>, but this often fails in the non-HTTP execution context of the search indexing process.
Please advise on how to safely access injected services within the DNN Search Indexing context, while adhering to DI best practices where possible.
Thank you very much for your guidance.
Constructor injection for that particular entry point will just work in DNN 10 when you upgrade. If you need DI there before upgrading to 10, you could do resolve the internal ServiceProvider using reflection like this:
[code]
var globalsType = typeof(DotNetNuke.Common.Globals);
var serviceProviderProperty = globalsType.GetProperty("DependencyProvider", BindingFlags.NonPublic | BindingFlags.Static);
var serviceProvider = (IServiceProvider)serviceProviderProperty.GetValue(null);
this.navigationManager = serviceProvider.GetRequiredService();
[/code]
Note: This is not best practice but a temporary solution until you get to DNN10, I would put a TODO in there to refactor that for simplicity and performance one you can target DNN10.
I reviewed your approach, but unfortunately I wasn’t able to use it.
The issue is with **IPortalSettings** — it remains **NULL** with every method I have tried.
Do you have any alternative solution?
I will be talking, doing a demo of DI in DNN in tomorrows co-coding session on discord. You can join our discord using a link we have on the home page of this site. If that interests you I'll also do a bit of Q&A there and we could look more deeply into it.
