DNN 9.3 Modules Missing in add module
Page 2 of 2 << < 12
It definitely could, but that's only a guess right now. If you can, inspecting the console for errors using the web developer tools in your web browser will help to determine that. It could also just be slow on your website.
Looked in the web browser developer tools did not see any that stood out but then again I am not a coder and really don't know I should be looking for. At this point I give up. Will contact the skin developer, see if they can help.
Thanks again for all you help.
I see this often with some themes and modules where some JavaScript captures the scroll event and prevents it from bubbling up to other scripts. Can you try to create a blank page, assign the default theme Excillion and try to reproduce the issue again.
Daniel,
Good call.
I created a blank page, assign the default theme Excillion and the add module pop up screen then was correct and listed all of the modules.
Then do I need to direct this issue back to the theme seller "JUSTDNN"?
Posted By Rob Greinke on 27 Jun 2019 05:40 PM
Daniel,
Good call.
Yeah, maybe. This sounds like it could be a more advanced compatibility issue.  If that doesn't work out, our team might be able to help.
Page 2 of 2 << < 12
