Documents Module ver. 8.3.1
After an upgrade to DNN ver 9.10.1 my Documents module do not work (Error: 2010 is not available)
I'll try to upgrade the Documents module, but where do i find the new version 8.3.1 ?
The Extensions page suggest this version, but the link (http://dnndocuments.dotnetnuke.com/) does not work.
I have a lot of documents and i dont want to spend months to try to restore all of them.
Posted By njhvidberg on 17 Sep 2021 06:08 AM
https://github.com/DNNCommunity/DNN.Documents
I think 07.01.00 is the latest version.
Thanks, i found it.
But how do i install it? If i use Install Extension and uploads the DNN.Documents-master.zip file i get 6 errors:
Info File DNN.Documents-master/Source\DotNetNuke.Documents.sln read successfully
EndJob Reading files done.
StartJob Reading Installation Manifest file
Info Reading Package Manifest - Module - DNN_Documents
Info Reading Component Manifest - Script
Failure File specified in the dnn could not be found in the zip file: - C:\Inetpub\vhosts\njhvidberg.dk\httpdocs\Install\Temp\4uwwk5pq\Providers\DataProviders\SQLDataProvider\install.06.00.00.SqlDataProvider
Failure File specified in the dnn could not be found in the zip file: - C:\Inetpub\vhosts\njhvidberg.dk\httpdocs\Install\Temp\4uwwk5pq\Providers\DataProviders\SQLDataProvider\06.00.00.SqlDataProvider
Failure File specified in the dnn could not be found in the zip file: - C:\Inetpub\vhosts\njhvidberg.dk\httpdocs\Install\Temp\4uwwk5pq\Providers\DataProviders\SQLDataProvider\Uninstall.SqlDataProvider
Info Reading Component Manifest - ResourceFile
Failure File specified in the dnn could not be found in the zip file: - C:\Inetpub\vhosts\njhvidberg.dk\httpdocs\Install\Temp\4uwwk5pq\Resources.zip
Info Reading Component Manifest - Cleanup
Info Reading Component Manifest - Module
Info Reading Component Manifest - Assembly
Failure File specified in the dnn could not be found in the zip file: - C:\Inetpub\vhosts\njhvidberg.dk\httpdocs\Install\Temp\4uwwk5pq\bin\DotNetNuke.Modules.Documents.dll
Click on the link to the latest release in the right column - 07.01.00 and then click and download DNN_Documents_07.01.00_Install.zip. That's what you want to download and upload to your site using the Install Extension on the Extensions Persona Bar page.
Thanks a lot, that worked!
