Existing Modules
I've recenlty ugraded to  9.6.1 and I'm having issues adding an existing module.  When I try to add an existing module it flashes and then disappears. A few times I could see it was added to the page via The Page>Advanced>Modules: listed in modules on this page but I couldn't view it.
I can see this workaround was added https://github.com/dnnsof...suecomment-552179624   (because I went to make the update.  That fix worked for me a few versions ago).
Any suggestions?
Thank you so much!
If this is still a problem, I'd recommending upgrading to the current release, but check the release notes first.
You can also report this as an issue at https://github.com/dnnsoftware/Dnn.Platform.
It is also possible that this is related to your skin. Check your browser's Console window for jQuery problems. You can also create a test page and use the Xcillion skin. Can you add the module to that page?
