Form builder form DNN 10
Looking for a form builder compatible with DNN 10 tha can replace DNN Sharp Action Form
Should do the same as DNN Sharp Action Form and better.
https://store.dnnsoftware.com/live-forms-9
https://store.dnnsoftware.com/megaform
Or is there a better alternative?
Willem, you can build forms using Dynamic Content solutions such as OpenContent, 2sxc or RocketCDS. Instead of using an specific module to build a Form. I personally like to use the form builder from DNNgo.net (https://www.dnngo.net/Our...es/FormBuilder.aspx)
New Member
New Member
You are a new member!
I make this one https://store.dnnsoftware.com/megaform-ai,
I think simple form can be any follow hint 2sxc or OpenContent that said,  but if you need a ready made, workflow, rules, intergration, vendor locked free submission you can have a look at megaform
  • Advanced Conditional Logic & Workflows:<!--TgQPHd|||[]--> Just like others, Megaform allows you to build complex, smart forms using an intuitive rule builder. You can easily create multi-step wizards, show/hide fields dynamically, and set up sequential multi-stage workflows without touching a single line of code.<!--TgQPHd|||[]--><!--TgQPHd|||[]-->
  • Deep DNN Integration & Extensibility:<!--TgQPHd|||[]--> It integrates seamlessly with the DNN 10 core backend. You can execute custom SQL queries to bind data dynamically, manage user registration/login overrides, and route submission data to external systems or legacy databases via robust HTTP Post and API integrations.<!--TgQPHd|||[]--><!--TgQPHd|||[]-->
  • Modern UI & Responsive Design out-of-the-box:<!--TgQPHd|||[]--> Unlike older modules that feel clunky on modern devices, Megaform features a cutting-edge drag-and-drop WYSIWYG editor. It automatically generates fully responsive layouts that render beautifully on desktops, tablets, and mobile phones.<!--TgQPHd|||[]--><!--TgQPHd|||[]-->
  • Enterprise Features:<!--TgQPHd|||[]--> It comes packed with built-in features such as secure data encryption, robust multi-language localization support, anti-spam mechanisms, file upload constraints, and seamless payment gateway integrations.<!--TgQPHd|||[]--><!--TgQPHd|||[]-->
  • Online premium free gallery like jotform updates frequently.
  • <!--TgQPHd|||[]-->
While dynamic content frameworks like 2sxc or OpenContent are great if you want to write custom C# code from scratch, Megaform gives you the best of both worlds: the absolute power of a developer tool combined with the rapid deployment of a no-code visual builder.
