Hiding a module from appearing on a mobile device
Trying to hide a module from appearing on a mobile device the Module is dnn sharp  action grid
So in the portal.css file I added the following:
@media only screen and (max-width: 768px) {
  .hide-mobile {
    display: none !important;
And then in module advanced setting under header tag I placed the following
  This content will only be visible on tablets and desktops.
This does not hide the hide the module on a mobile device – what am I missing?
Bob
oops
in the module under header tag i placed
why is css not showing up
meta name="viewport" content="width=device-width, initial-scale=1">
div class="hide-mobile">
div>
 @Bob M, html, xml, and css needs to be surrounded by "code" tags to be properly displayed. Here is some documentation on that:
https://github.com/DNNCom...-To-Enter-XML-&-HTML
Just a guess here but I think there is a new security setting in DNN 9.13.10 (and somewhere in the DNN 10 version lineage, 10.2?) to enable html in the module header.
Trying to hide a module from appearing on a mobile device the Module is dnn action grid
  .hide-mobile {
<code><meta name="viewport" content="width=device-width, initial-scale=1"></code>
<code><<div class="hide-on-mobile"></code>
<code></div></code>
Well, in the code I see a div opening with << so that could create an issue.
Another thing is that the class name in the HTML is not the same as the css class.
I never tried to add the HTML in the header tag btw. I either add the class in the HTML of the module or use the ID of the module to set the display none
Tycho  thanks for that information
