HTML CKEditor in v 09.03.02 (24) is missing Syntax highlighter tool
I have recently installed DNN v 09.03.02 (24) on my laptop.
When I login as host and edit html content, the CK Editor shows up ( and not Telerik RadEditor as was the case in older versions). The problem is that these 2 tools are not showing up on toolbar even though they are part of the Full toolset - syntax higlighter and MathJax .I have checked that these 2 tools are included in toolbar by going to Site Settings > Site Behavior > HTML Editor Manager > CKEditor Settings.
Do I need to do something extra to have these 2 tools show up in CKEditor toolbar?
I think we have the same issue on this site and did not find the solution yet.
As Timo mentioned, this is an issue that we're also experiencing, which means that the implementation of the buttons themselves has a bug in the DNN provider. I've even tried manually editing the configuration files since the web-based editor doesn't appear to work at all. :(
An issue hasn't yet been created in GitHub either.
