HTML Module
The site is running DNN 09.00.02. By accident the HTML module is deleted. Is there a plan to reinstall it for the site without starting all over again.
I copied the site to my local computer and the HTML module can be used, but on the website it is not available.
When you say 'deleted', do you mean uninstalled?
Because if you just delete from a page, you can find and restore in the trash can.
Yes, I mean uninstall.
I solved the issue, thank you. I copied the everything to my desktop and it work 100%. I copied it back to the web and it is working now.
