HTMLEditorManager not working after upgrade to DNN 9.4
I get the following error messages when I launch the HTML Editor Manager
Current Provider:
 CKHtmlEditorProvider
The current HTML Editor Provider is not supported by this version of the HTML Editor Manager.
Error: CKEditor Provider Config Manager is currently unavailable. DotNetNuke.Services.Exceptions.ModuleLoadException: It is an error to use a section registered as allowDefinition='MachineToApplication' beyond application level. This error can be caused by a virtual directory not being configured as an application in IIS. (E:\web\talking1\providers\web.config line 164) ---> System.Configuration.ConfigurationErrorsException: It is an error to use a section registered as allowDefinition='MachineToApplication' beyond application level. This error can be caused by a virtual directory not being configured as an application in IIS. (E:\web\talking1\providers\web.config line 164) at System.Configuration.ConfigurationSchemaErrors.ThrowIfErrors(Boolean ignoreLocal) at System.Configuration.BaseConfigurationRecord.ThrowIfParseErrors(ConfigurationSchemaErrors schemaErrors) at System.Configuration.BaseConfigurationRecord.GetSectionRecursive(String configKey, Boolean getLkg, Boolean checkPermission, Boolean getRuntimeObject, Boolean requestIsHere, Object& result, Object& resultRuntimeObject) at System.Configuration.BaseConfigurationRecord.GetSection(String configKey) at System.Web.Configuration.RuntimeConfig.GetSectionObject(String sectionName) at System.Web.Configuration.RuntimeConfig.GetSection(String sectionName, Type type, ResultsIndex index) at System.Web.Configuration.RuntimeConfig.get_Compilation() at MTConfigUtil.GetCompilationConfig(VirtualPath vpath) at System.Web.Compilation.BuildProvidersCompiler..ctor(VirtualPath configPath, Boolean supportLocalization, String outputAssemblyName) at System.Web.Compilation.CodeDirectoryCompiler.GetCodeDirectoryAssembly(VirtualPath virtualDir, CodeDirectoryType dirType, String assemblyName, StringSet excludedSubdirectories, Boolean isDirectoryAllowed) at System.Web.Compilation.BuildManager.CompileCodeDirectory(VirtualPath virtualDir, CodeDirectoryType dirType, String assemblyName, StringSet excludedSubdirectories) at System.Web.Compilation.BuildManager.EnsureFirstTimeDirectoryInit(VirtualPath virtualDir) at System.Web.Compilation.BuildManager.GetBuildResultFromCacheInternal(String cacheKey, Boolean keyFromVPP, VirtualPath virtualPath, Int64 hashCode, Boolean ensureIsUpToDate) at System.Web.Compilation.BuildManager.GetVPathBuildResultFromCacheInternal(VirtualPath virtualPath, Boolean ensureIsUpToDate) at System.Web.Compilation.BuildManager.GetVPathBuildResultInternal(VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile, Boolean throwIfNotFound, Boolean ensureIsUpToDate) at System.Web.Compilation.BuildManager.GetVPathBuildResultWithNoAssert(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile, Boolean throwIfNotFound, Boolean ensureIsUpToDate) at System.Web.UI.TemplateControl.LoadControl(VirtualPath virtualPath) at DotNetNuke.UI.ControlUtilities.LoadControl[T](TemplateControl containerControl, String ControlSrc) at DotNetNuke.UI.Modules.WebFormsModuleControlFactory.CreateControl(TemplateControl containerControl, String controlKey, String controlSrc) at DotNetNuke.UI.Modules.WebFormsModuleControlFactory.CreateModuleControl(TemplateControl containerControl, ModuleInfo moduleConfiguration) at DotNetNuke.ModulePipeline.ModuleControlPipeline.LoadModuleControl(TemplateControl containerControl, ModuleInfo moduleConfiguration) at DotNetNuke.UI.Modules.ModuleHost.LoadModuleControl() --- End of inner exception stack trace ---
What is on line 164 in the web.config?
first make a backup of the web.config
remove the web.config in the folder provider.
Posted By Mariette Knap on 14 Jan 2020 07:24 AM
I have solved the problem. I had mistakenly uploaded a web.config to the providers folder. This was causing me all kinds of problems.
