Line breaks using SendMail method
Hi, I want to send values from a form in a custom module to an email box. I used the chris hammond recommended method and tried passing the form values with line breaks in a body variable
 DotNetNuke.Services.Mail.Mail.SendMail("[email protected]", "[email protected]", "", "THIS IS THE SUBJECT", body, "", "HTML", "", "", "", "" );
It works fine , but no matter what I do the values all line up on one long line in outlook,  rather than the vertical list I want.
I have tried several methods with \n, \r\n,Environment.Newline  for example
string body = @"  From: " + txtFirstName.Text + Environment.NewLine;
        body += "  Email: " + txtEmail.Text + Environment.NewLine;
        body += "  Subject: " + txtSubject.Text + "\r\n";
        body += "  Question: \n" + txtComments.Text + "\r\n";
I have even tried using stringBuilder appendline in several ways but still no joy
StringBuilder sb = new StringBuilder();
        sb.Append("  \r\n\r\n").Append("Name: " + txtFirstName.Text +'\n');
        sb.Append("  \r\n\r\n").Append("Email: " + txtEmail.Text +'\n');
        sb.AppendLine("Subject: " + txtSubject.Text +'\n');
        sb.AppendLine("Comments: " + txtComments.Text +'\n');
        string body = sb.ToString();
Has anyone got a working example??
If it's an HTML email, it may be you need to add line break elements. So instead of \n try adding < br > (but without the extra spaces - adding code snippets on this forum is hard!)
Yes, you are absolutely right, I missed I had added the HTML parameter. doh too close methinks.
