Multiple Digarticle Modules in single row
Page 2 of 2 << < 12
Did you check if there is an HTML error on the page? Those can cause these kind of issues too..
Checked for HTML error also, nothing such error found. Seems that by defualt DNN doesn't support multiple dig article modules in same row.
I would recommend reaching out to the module vendor for support.
Posted By Nitin on 6/17/2024 11:37 AM
Can you add this to your CSS and see it it helps?
<code><span style="color: #800000;">#Body</span><span style="color: #000000;"> </span><span style="color: #800000;">.dnn_menu_label</span><span style="color: #000000;">{</span></code>
<code><span style="color: #000000;">    </span><span style="color: #ff0000;">display:</span><span style="color: #000000;"> </span><span style="color: #0451a5;">none</span><span style="color: #000000;"> </span><span style="color: #0000ff;">!important</span><span style="color: #000000;">;</span></code>
<code><span style="color: #000000;">}</span></code>
It hides the title lable for dig article, however does't make any helpful impact for showing controls for second dig article module in same row.
Ok in that case I'm out of ideas.
This is some kind of issue of the module, did you contact Dig support?
At this point, you can use the link to this forum thread when you create your support request with DigNuke. 😉
Page 2 of 2 << < 12
