.NET framework used between website and custom extension
I hope someone can clarify this for me.
I'm running an ASP.NET website in IIS (DotNetNuke to be exact). I also have a module that is installed on the site that was custom built.
My IIS web.config specifies a "targetFramework" of "4.5" (under the system.web/httpRuntime element). My custom module was built with a target framework of "4.7.2".
When the custom module is loaded by the website, is it now running under the .NET 4.5 framework because that's what the website's web.config was targetting?
I think that means you are using an older version of DNN.
AFAIK DNN 9.8 requires 4.7.2
But anyway as long as that version of .NET is installed your module should work and DNN will run on the newer version too.
(Side note, upgrade your DNN version for security reasons:-)
Let's say I did upgrade to DNN 9.8 and its web.config is stating that the target runtime should be 4.7.2. Does that mean a DNN module/extension I built that targets the 4.8 runtime would only be running with a max runtime of 4.7.2 because DNN/IIS loaded it with a framework of 4.7.2?
Not if you installed 4.8 on the hosting machine.
4.7.2 is the minimum version needed
