New modules disappear
DNN 9: Site is 80% complete but now when I add a new module, it disappears. By "disappear" I mean I drag the module onto a pane, the page reloads, and then the module is not there. If I go out of edit mode I can sometimes see that the module was successfully added to the page, but once I go back into edit mode, I can't see the module. We are using 2sxc structured content along with regular HTML modules.
Can you tell a bit more?
What DNN 9 version?
What 2SXC version?
Does it happen with the 2SXC content or app module? Or both?
Does it happen to 2SXC modules only or HTML modules as well?
DNN 9.2.2
2sxc 10
Content module
Also happens with HTML
Most of the time when I find modules seemingly disappearing from a website, it's either the theme or a third-party module causing this to happen. Usually, it's an underlying and sometimes suppressed error message or the theme is using legacy features, including TABLE tags. One of the ways to troubleshoot this is to one-by-one recreate the page in question manually on another test page until you find the module and/or module configuration that is the root cause. Good luck! :)
