Personabar not working without language in URL
I have DNN 9.10 website, with 2 portals.
There is this problem i can not get hold of to fix.
These are my steps:
  1. Go to your dnnsite → www.yourdomain.com/nl-be/login
    Login whit your credentials.
  2. after i get logged in i am redirected to https://www.yourdomain.com/nl-be/  (So far so good)
  3. When i go to www.yourdomain.com (without language → the personabar is there without icons/buttons.)
  4. When i go to site aliases → i have these settings:
    1. www.yourdomain.com/nl-BE   → nl-BE  → primary YES
    2. www.yourdomain.com             → nl-BE  → No
    3. www.yourdomain.com/fr-FR   → fr-Fr → No
How can we fix this that www.yourdomain.com → redirects to www.yourdomain.com/nl-BE
Try to change www.yourdomain.com (#2 in the list above) to the primary domain (and remove that flag from www.yourdomain.com/nl-BE). Then restart the application pool. Does that work?
you should have one primary alias for each language alias and one neutral one for the landing page, i.e.
  1. www.yourdomain.com                → (neutral)  → primary YES
  2. www.yourdomain.com/nl-BE     → nl-BE       → primary YES
  3. www.yourdomain.com/fr-FR      → fr-FR       → primary YES
@Michael did test your feedback and it's not working.
Posted By Sebastian Leupold on 24 Aug 2021 10:03 PM
I would like to change site alias like you describe above but it's not working properly in DNN.
First i go to https://www.yourdomain.be/fr-fr/ → because i can not edit nl-be or without.
Is this behavior inside dnn sitebehavior normal that when i change https://www.yourdomain.be/nl-be → To primary site,
it's unchecking https://www.yourdomain.be automaticly
And if I do this in the other way i get the same result. (only different direction)
But you can change values in database as well. → in table PortalAlias, there i set the value to true.
After that i did restart and i get the same result as screenshot above.
I have some question about personabar:
→ does the personabar require the language to work properly?
I think we need to solve this in a different way.
If we use only https://www.yourdomain.be it should redirect the site to https://www.yourdomain.be/nl-be  (then the problem is gone)
The problem only exists for the logged in users.
Posted By Nobels on 31 Aug 2021 03:13 AM
Please note that your browser caches the redirects generated, which can get really confusing (and is very annoying)
Always test this in a new Private window, or you might get confused.
