Problem installing module
Trying to install a forms module and got the attached error code/message.
StartJob Starting Installation
Info Starting Installation - Action Form
Info Starting Installation - Cleanup
Info Processing Cleanup File - 5.7.16
Info Completed Processing of Cleanup File - 5.7.16
Info Component installed successfully - Cleanup
Info Starting Installation - Script
Info Begin Sql execution
Info Creating backup of previous version - DataProviders.ActionForm\SqlDataProvider\01.02.00.SqlDataProvider
Info Created - DataProviders.ActionForm\SqlDataProvider\01.02.00.SqlDataProvider
Info Executing 01.02.00.SqlDataProvider
Info Start Sql execution: 01.02.00.SqlDataProvider file
Failure SQL Execution resulted in following Exceptions: System.Data.SqlClient.SqlException (0x80131904): Column already has a DEFAULT bound to it. Could not create constraint. See previous errors. at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction) at System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction) at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose) at System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady) at System.Data.SqlClient.SqlCommand.RunExecuteNonQueryTds(String methodName, Boolean async, Int32 timeout, Boolean asyncWrite) at System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(TaskCompletionSource`1 completion, String methodName, Boolean sendToPipe, Int32 timeout, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry) at System.Data.SqlClient.SqlCommand.ExecuteNonQuery() at DotNetNuke.Data.SqlDatabaseConnectionProvider.ExecuteNonQuery(String connectionString, CommandType commandType, Int32 commandTimeout, String query) at DotNetNuke.Data.SqlDataProvider.ExecuteScriptInternal(String connectionString, String script, Int32 timeoutSec) ClientConnectionId:13074c47-3ff6-4ab3-b1e0-02995978109e Error Number:1781,State:1,Class:16 ALTER TABLE dbo.[avtActionForm_FormFields] ADD CONSTRAINT [DF_avtActionForm_FormFields_ColIndex] DEFAULT ((1)) FOR [ColIndex] System.Data.SqlClient.SqlException (0x80131904): Column already has a DEFAULT bound to it. Could not create constraint. See previous errors. at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction) at System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction) at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose) at System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady) at System.Data.SqlClient.SqlCommand.RunExecuteNonQueryTds(String methodName, Boolean async, Int32 timeout, Boolean asyncWrite) at System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(TaskCompletionSource`1 completion, String methodName, Boolean sendToPipe, Int32 timeout, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry) at System.Data.SqlClient.SqlCommand.ExecuteNonQuery() at DotNetNuke.Data.SqlDatabaseConnectionProvider.ExecuteNonQuery(String connectionString, CommandType commandType, Int32 commandTimeout, String query) at DotNetNuke.Data.SqlDataProvider.ExecuteScriptInternal(String connectionString, String script, Int32 timeoutSec) ClientConnectionId:13074c47-3ff6-4ab3-b1e0-02995978109e Error Number:1781,State:1,Class:16 ALTER TABLE dbo.[avtActionForm_FormFields] ADD CONSTRAINT [DF_avtActionForm_FormFields_DateCreated] DEFAULT (getdate()) FOR [DateCreated] System.Data.SqlClient.SqlException (0x80131904): There is already an object named 'FK_ActionForm_Reports_Modules' in the database. Could not create constraint. See previous errors. at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction) at System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction) at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose) at System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady) at System.Data.SqlClient.SqlCommand.RunExecuteNonQueryTds(String methodName, Boolean async, Int32 timeout, Boolean asyncWrite) at System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(TaskCompletionSource`1 completion, String methodName, Boolean sendToPipe, Int32 timeout, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry) at System.Data.SqlClient.SqlCommand.ExecuteNonQuery() at DotNetNuke.Data.SqlDatabaseConnectionProvider.ExecuteNonQuery(String connectionString, CommandType commandType, Int32 commandTimeout, String query) at DotNetNuke.Data.SqlDataProvider.ExecuteScriptInternal(String connectionString, String script, Int32 timeoutSec) ClientConnectionId:13074c47-3ff6-4ab3-b1e0-02995978109e Error Number:2714,State:5,Class:16 ALTER TABLE dbo.[avtActionForm_Reports] WITH CHECK ADD CONSTRAINT [FK_ActionForm_Reports_Modules] FOREIGN KEY([ModuleId]) REFERENCES dbo.[Modules] ([ModuleID]) ON DELETE CASCADE System.Data.SqlClient.SqlException (0x80131904): Column already has a DEFAULT bound to it. Could not create constraint. See previous errors. at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction) at System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction) at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose) at System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady) at System.Data.SqlClient.SqlCommand.RunExecuteNonQueryTds(String methodName, Boolean async, Int32 timeout, Boolean asyncWrite) at System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(TaskCompletionSource`1 completion, String methodName, Boolean sendToPipe, Int32 timeout, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry) at System.Data.SqlClient.SqlCommand.ExecuteNonQuery() at DotNetNuke.Data.SqlDatabaseConnectionProvider.ExecuteNonQuery(String connectionString, CommandType commandType, Int32 commandTimeout, String query) at DotNetNuke.Data.SqlDataProvider.ExecuteScriptInternal(String connectionString, String script, Int32 timeoutSec) ClientConnectionId:13074c47-3ff6-4ab3-b1e0-02995978109e Error Number:1781,State:1,Class:16 ALTER TABLE dbo.[avtActionForm_Reports] ADD CONSTRAINT [DF_ActionForm_Reports_UserId] DEFAULT ((-1)) FOR [UserId] System.Data.SqlClient.SqlException (0x80131904): Column already has a DEFAULT bound to it. Could not create constraint. See previous errors. at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction) at System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction) at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose) at System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady) at System.Data.SqlClient.SqlCommand.RunExecuteNonQueryTds(String methodName, Boolean async, Int32 timeout, Boolean asyncWrite) at System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(TaskCompletionSource`1 completion, String methodName, Boolean sendToPipe, Int32 timeout, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry) at System.Data.SqlClient.SqlCommand.ExecuteNonQuery() at DotNetNuke.Data.SqlDatabaseConnectionProvider.ExecuteNonQuery(String connectionString, CommandType commandType, Int32 commandTimeout, String query) at DotNetNuke.Data.SqlDataProvider.ExecuteScriptInternal(String connectionString, String script, Int32 timeoutSec) ClientConnectionId:13074c47-3ff6-4ab3-b1e0-02995978109e Error Number:1781,State:1,Class:16 ALTER TABLE dbo.[avtActionForm_Reports] ADD CONSTRAINT [DF_ActionForm_Reports_RedirectedDateTime] DEFAULT (getdate()) FOR [DateSubmitted]
Info End Sql execution: 01.02.00.SqlDataProvider file
Info Finished Sql execution
Failure Installation Failed - Script
Info Rolling back component install - Cleanup
Info Component rolled back successfully - Cleanup
Info Installation Failed - Action Form
Info Deleted temporary install folder
EndJob Installation Failed
Contact DNNSharp's support team. They should be able to help you.
