Resource Manager - column sorting
I'm running DNN 9.13.3. I had some users complain about the column sorting in the Resource Manager. It looks like you can select a column to sort by, but you cannot change the sort direction. In other words, you can't sort so the most recent assets are seen on top of the list.
Does anyone know if this issue is being addressed in newer versions of the Resource Manager?
Tom
Not yet, I'll be working in that area shortly if I see it is quick, I'll keep an eye on potentially fixing that.
Thanks for your reply Daniel.
I also wanted to make sure I wasn't missing anything, it sounds like I'm correct that the sorting can't be reversed so that the most recent item is on top.
Thanks again and let me know when that is updated.
The Resource Manager is great -
Cheers!
Tom
I won't remember to come back here when it is done. If you want to know when it is done, you can subscribe to this issue https://github.com/dnnsof...Platform/issues/5430
Sounds good, thank you
