Unable to edit pages
We recently discovered that are unable to edit pages on our site.  I added a page to the site and after that I am unable to save edits to HTML modules.  We did try changing the theme and container and are still having the same issue.  There have been no updates to the skin recently.  Any thoughts on what to try next?
Is this as an admin? If you are logged in as an editor for instance, the permissions might prevent you from editing. Note that permission can be set on page level or on module level.
Yes, I am logged in as a Super User.
Is this new behavior?
Which version of DNN?
Have you upgraded recently?
If so, from which version?
Which HTML Editor Provider are you using?
It is a new behavior.
We are using v. 09.01.01
This site has not been upgraded recently.
Not for sure about the HTML editor provider.  This is what it says in the site configuration:
If you look at Site Settings, More you should be able to see the HTML Editor Provider.
As this is new behavior and you haven't done an upgrade, take a look at your browser's Console window to see if there are errors reported, especially javascript errors.
The site uses CKEditor Provider Config Manager
