I have a new site I am building for a French organisation (non-commercial). I have installed 9.10.2.
I would like to have the internals in French as this will help understanding. I have found a FR-fr language pack in GitHub labelled version 9.9.1.
Will this mismatch of version numbers be a problem.
Many thanks, you are always helpful.
Simon Thompson
Perfect! It worked like a dream.
Simon,
it does not matter if you search for that on a local (development) server or a production server. The point is to find the file that you want to change, and assuming I want to change the phrase "Reset Password" (button on the registration form) I do it like this: I open Notepad++, then I go to Search >> Find in Files (Ctrl + Shift + F), and enter the following:
Then I click the "Find All" button. This gives me the following result:
<code>D:\Web\DnnRoot\admin\Security\App_LocalResources\SendPassword.ascx.resx (2 hits)<br /> Line 145: <value>Reset Password</value><br /> Line 196: <value>Reset Password</value><br /> D:\Web\DnnRoot\DesktopModules\Admin\Security\App_LocalResources\ManageUsers.ascx.resx (1 hit)<br /> Line 155: <value>Reset Password</value><br /> D:\Web\DnnRoot\DesktopModules\AuthenticationServices\DNN\App_LocalResources\Login.ascx.resx (1 hit)<br /> Line 139: <value>Reset Password</value></code>
Then I use the localization (translation) editor on my site to correct these words in these file(s), either in another language or for the host or the portal - but not for "Global" if it's Englisch (US), because this could be overwritten by an update.
Hope that helps...
Happy DNNing! Michael
