Browser language detection broken after upgrade
 5 Subscribed to this topic
 25 Subscribed to this forum
Hello, I have upgrade a website from 9.2 to 9.11 and  now the detection of browser language is not done anymore if portal alias is not correct. I am able to reproduce issue 100% by downloading clean install of both versions from github.
Step to reproduce :
  • Create Website normally
  • Add a new language
  • Allow LocalizedContent, Enable Localized Content, Enable Browser Language Detection
  • Make the home page available for both default and new language
  • Go to Site Behavior -> Site aliases and unassign primary site alias without language (to force people having the language in the url)
  • Open incognito tab and browse home page (without any language in the url)
In 9.2 we were redirect to browser language, in 9.11 users are redirected to the default system language.
Thanks in advance
If this is a reproducable bug, you should document it here:
Issues · dnnsoftware/Dnn.Platform · GitHub
Did you also try this in a Private Browser window?
Browsers are notorious for caching 301 redirects..
7 Engaged Reader
Have you double check that everything looks okay in section "Site Settings -> Site Aliases"?
Thanks for your answers.
Yes I tryed private mode and even others browsers. As mentionned we are able to reproduce it 100% even from clean configuration by creating a DNN website.
What do you mean by "everything looks okay". Because yes everything is supposed to be okay
We can't quite answer you intelligently about whether or not your Site Aliases look okay or not.  That's something that only you can know.
In general, you should only ever have the URLs that the site should respond to, and only one as a primary domain name.  The rest should be redirects/rewrites or deleted altogether.
I am having a similar issue. I just upgraded to 9.10.2 and I only have one site that is localized. That one site in my testing environment, that is running 9.10.2, works fine and sets the language cookie and all things that depend on the cookie changes like it should. In my production site the language cookie isn't being set, it remains null, so things that are built into the skin that depend on the cookie doesn't translate.
Site aliases look ok and the site responds to all the aliases, though not all of them have a language associated with them, only the specific localized URLs. The base URLs I don't have the language set for them.
And the production site is the same DNN version?
check for differences in your IIS configuration
this might be relevant?... https://www.itnota.com/en...ttponly-cookies-iis/
Yes both test and production sites use the same version.
