Trying to change the selector text English (United States) Português (Portugal) Français (France) العربية (مصر) and shorten choice of language section. e.g. ENG, PORT, FR, etc
Sequii,
this is not really complicated: in the skin file you find something like
{dnn:language id="dnnLanguage" runat="server" showlinks="True" showmenu="False" /}
Replace this by
{dnn:LANGUAGE runat="server" ID="dnnLanguage" ShowLinks="True" ShowMenu="False" ItemTemplate='{a href="[URL]" title="[CULTURE:NATIVENAME]"}{span class="Language" style="text-transform: uppercase;"}[CULTURE:THREELETTERISOCODE]{/span}{/a}' AlternateTemplate='{a href="[URL]" title="[CULTURE:NATIVENAME]"}{span class="Language" style="text-transform: uppercase;"}[CULTURE:THREELETTERISOCODE]{/span}{/a}' SelectedItemTemplate='{span class="Language selected" title="[CULTURE:NATIVENAME]" style="text-transform: uppercase;"}[CULTURE:THREELETTERISOCODE]{/span}' /}
Replace { by < and } by >. Find more info here: https://www.dnnsoftware.c...language-skin-object
Happy DNNing! Michael
Hello Michael,
I applied those settings and the site theme looses the css and doesnt change the menu so i started to break this up some. When applying just these setting nothing changes either. https://drive.google.com/...fcbgM0ewefFom_ZdJWts ^ Image of .ascx file. {dnn:language id="dnnLanguage" runat="server" showlinks="True" showmenu="False" ItemTemplate='{a href="[URL]" title="[CULTURE:NATIVENAME]"}{span class="Language" style="text-transform: uppercase;"}[CULTURE:THREELETTERISOCODE]{/span}{/a}'/}
https://www.dnnsoftware.c...skinobject-explained Read this and when chaging some of this code do see the site take. I'm using inner.ascx those are my sub pages on nxa.org. Tried clearing cache. Just cant get this to work. Thanks for the help.
Please note that you shoudl also add an "AlternateTemplate". I think I would use:
< dnn:LANGUAGE runat="server" id="dnnLANGUAGE" showMenu="False" showLinks="True" ItemTemplate='< a href="[URL]" class="Language [CULTURE:THREELETTERISOCODE]" title="[CULTURE:NATIVENAME]">[CULTURE:THREELETTERISOCODE]< /a>' AlternateTemplate='< a href="[URL]" class="Language [CULTURE:THREELETTERISOCODE]" title="[CULTURE:NATIVENAME]">[CULTURE:THREELETTERISOCODE]< /a>' SelectedItemTemplate ='< a href="[URL]" class="Language [CULTURE:THREELETTERISOCODE] Selected" title="[CULTURE:NATIVENAME]">[CULTURE:THREELETTERISOCODE]< /a>' />
hi again.
This shows what my site looks like after applying. https://drive.google.com/...r9joTd_5scAXx-A2fiuz Just want it to look like https://drive.google.com/...25FKnl7K95oCa6L8MSRf
Posted By sequii on 18 Feb 2020 01:05 PM hi again. This shows what my site looks like after applying. https://drive.google.com/...r9joTd_5scAXx-A2fiuz Just want it to look like https://drive.google.com/...25FKnl7K95oCa6L8MSRf
please first the remove the spaces I added to circomvent the forum editor (< a) Also make sure the html you past in your skin is not encoded.
Thanks for the help. http://nxa.org/en-us/About/Mission top right corner engporfraara The scope was to have the drop down selector for langauges display eng por fra ara Right now they are just links. If I showlinks to false it shows the regular english titles.
In this case you should try:
ShowLinks="False" ShowMenu="True"
as attributes of the menu control.
Posted By sequii on 20 Feb 2020 04:16 PM Thanks for the help. http://nxa.org/en-us/About/Mission top right corner engporfraara The scope was to have the drop down selector for langauges display eng por fra ara Right now they are just links. If I showlinks to false it shows the regular english titles.
AFAIK there's no drop-in solution for that. You would have to use render a ul (change the template) and add some CSS
Thanks Michael but yes when i do that it just shows the full langauge on the selector.
