Lost subpages after renaming parent
 25 Subscribed to this forum
I've been created localised version of a number of pages which were all under a parent page on the menu. I then had to change the tabname of the parent, so i localised the parent and changed the page name, but now my sub pages are no longer visible in the menu and when i under 'Pages' the branch is empty.
The pages are still listed correctly in the default language and if i query the database the localised tab pages are still there.
I guess that its broken the parent link somehow - any ideas of how to get the localised pages back.
The TabId of the parent page is stored in the Tabs table - did you check if they are there correctly?
Posted By Johnhols on 17 Aug 2021 06:08 AM
Ok, so the parent page was a neutral (not localized) page with localized child pages before you change to to localized?
The parentid are stored against the subpages in the tabs table, its the same parentid for each of the localised pages
The parent page was only localised after the subpages had been localised, which has caused the problem.
I've bit the bullet and restored the database to try again, this time i've started by localising the parent and then working my way down the branches, what i have found now is that only the localised subpages appear on the localised branch, it doesn't include any unlocalised pages.
Looking at the database it's created a completely new branch for each language, looking at SQL the branch is called Solutions,
tabid    taborder    parentid    tabname    url    CultureCode    contentitemid    tabpath
200    15    NULL    Solutions    293    en-US    612    //Solutions
803    27    NULL    Solutions (de-DE)    293    de-DE    5341    //Solutions(de-DE)
804    25    NULL    Solutions (es-ES)    293    es-ES    5347    //Solutions(es-ES)
805    23    NULL    Solutions (fr-FR)    293    fr-FR    5353    //Solutions(fr-FR)
806    21    NULL    Solutions (nl-NL)    293    nl-NL    5359    //Solutions(nl-NL)
807    19    NULL    Solutions (sv-SE)    293    sv-SE    5365    //Solutions(sv-SE)
808    17    NULL    Solutions (da-DK)    293    da-DK    5371    //Solutions(da-DK)
Rows where parentid=200 (Solutions)
293    1    200    Overview        en-US    917    //Solutions//Overview
584    3    200    Document management    614    en-US    3446    //Solutions//Documentmanagement
257    5    200    Expense management    615    en-US    744    //Solutions//Expensemanagement
Rows where parentid=584 (Solutions --> Document Management Sub-branch)
614    1    584    Overview        en-US    3513    //Solutions//Documentmanagement//Overview
261    3    584    Proof of delivery    NULL    NULL    758    //Solutions//Documentmanagement//Proofofdelivery
260    5    584    Supplier invoice processing        en-US    754    //Solutions//Documentmanagement//Supplierinvoiceprocessing
263    7    584    Invoice approval    NULL    en-US    766    //Solutions//Documentmanagement//Invoiceapproval
746    9    584    Remittance advice    NULL    en-US    4432    //Solutions//Documentmanagement//Remittanceadvice
262    11    584    Sales order processing    NULL    en-US    762    //Solutions//Documentmanagement//Salesorderprocessing
259    13    584    Electronic invoicing    NULL    en-US    750    //Solutions//Documentmanagement//Electronicinvoicing
258    15    584    Collections management    NULL    NULL    745    //Solutions//Documentmanagement//Collectionsmanagement
Rows where parentid=805 (French version of Solutions branch)
811    3    805    Overview (fr-FR)        fr-FR    5395    //Solutions(fr-FR)//Overview(fr-FR)
817    5    805    Document management (fr-FR)    614    fr-FR    5439    //Solutions(fr-FR)//Documentmanagement(fr-FR)
835    7    805    Expense management (fr-FR)    615    fr-FR    5573    //Solutions(fr-FR)//Expensemanagement(fr-FR)
Rows where parentid=817 (French Solutions --> Document Management Sub branch)
823    3    817    Overview (fr-FR)        fr-FR    5467    //Solutions(fr-FR)//Documentmanagement(fr-FR)//Overview(fr-FR)
829    7    817    Supplier invoice processing (fr-FR)        fr-FR    5511    //Solutions(fr-FR)//Documentmanagement(fr-FR)//Supplierinvoiceprocessing(fr-FR)
883    9    817    Invoice approval (fr-FR)        fr-FR    6013    //Solutions(fr-FR)//Documentmanagement(fr-FR)//Invoiceapproval(fr-FR)
889    11    817    Remittance advice (fr-FR)        fr-FR    6067    //Solutions(fr-FR)//Documentmanagement(fr-FR)//Remittanceadvice(fr-FR)
895    13    817    Sales order processing (fr-FR)        fr-FR    6123    //Solutions(fr-FR)//Documentmanagement(fr-FR)//Salesorderprocessing(fr-FR)
901    15    817    Electronic invoicing (fr-FR)        fr-FR    6183    //Solutions(fr-FR)//Documentmanagement(fr-FR)//Electronicinvoicing(fr-FR)
If i recall correctly, previously the localised subpages where still under the Solutions branch, so any non-localised pages would still appear. I think this is how it should work.
My next step is too rename the localised tab pages and hope the structure stays in place.
I have had strange issues too and untill now it was always a DB inconsistancy that existed before localising.
Most common was a parent that had a different language from the child page.
try:
<code>SELECT<br />     <br />     Tabs.TabID,<br />     Tabs.PortalID,<br />     Tabs.TabName,<br />     Tabs.ParentId,<br />     Tabs.TabPath,<br />     Tabs.IsDeleted,<br />     Tabs.CultureCode as TabCultureCode,<br />     ParentTabs.TabName as ParentTabName,<br />     ParentTabs.CultureCode AS ParentCultureCode,<br />     Tabs.Level as TabLevel,<br />     ParentTabs.Level AS ParentLevel<br /> FROM         Tabs INNER JOIN<br />                       Tabs AS ParentTabs ON Tabs.ParentId = ParentTabs.TabID<br /> WHERE NOT Tabs.ParentId IS NULL AND not (Tabs.CultureCode = ParentTabs.CultureCode) and tabs.PortalID = x</code>
