Adding a JS slide-out panel for contact form
Hi DNN brethren,
The website I'm currently working on needs to have an always-available (desktop and mobile) contact form, ideally in the form of a sticky side-button or icon, that when clicked, a panel slides out and contains a nice modern-looking contact form.
I'm trying figure out the most efficient way to accomplish this - I've used ActionForm modules pretty extensively, also would be open to trying Mandeeps LiveForms, but can I add that sliding panel idea as a layout pane in the skin? I've found one other commercial form module that already comes with that option, but isn't a very attractive form without a lot of restyling, and not a very smooth animation.
Any suggestions for this? I'll be converting an HTML template from ThemeForest that has an HTML form example of this type of thing included.
Thanks for any guidance!
David
You should be able to create a content pane in your skin and animate it to slide in and out. Then, you can add your favorite module (which could be a form module) to that pane.
I've done things like this with Bootstrap tabs and accordions that include content panes within the content of the tabs or accordion elements. I think that there may be some modules that allow you to do this as well.
Here is an example of a tab structure built into a skin file: https://hsc.com/Services/...ng-Services/Embedded
Remember that a DNN page is just an HTML page, so if you can do something in HTML you can do it in DNN.
Thanks, Joe! I should be able to do that -  I'll be using a purchased HTML theme converting to a DNN skin, and I should be able to adapt the particular structure for the slide-out panel, but include the layout pane div inside of that to be able to drop in a form module.
It would be kind of nice to have it all be part of the module, but it's probably better to be able to make it be exactly the way I need it.
Thanks again!
David
