Blank Skin?
Wish I could find my old login creds.  But it's been a few years since I have logged in.  :-(
I have an old blank skin but it is for DNN 4 I think and I doubt it would work on DNN 9+.  Does anyone know where I could find an updated blank skin?
Thanks;
Greg Brown
If it's totally empty, then it should work with current DNN 9.
The only requirement is that it have a content pane named ContentPane.
Regarding your lost login cred, you can register a new user and set the user as IsSuperUser from DB
Don't know if those field is available on DNN 4
Thanks Joe!
By the looks of your post count my old DNN sign in wouldn't work on this new community site even if I could remember it. As I know your all time post count is much higher than 898!!!
You will need to remove the solpartmenu skin object too from the container.
If you have upgraded already to the latest DNN 9 version, simply use the default DNN skin. If you want a totally blank skin, you can copy or rename the skin and modify the skin file. I think that would be the best solution for you. Those skins are responsive. I do not think your old DNN 4 skin will work like that.
